do i need to upgrade the valve train
Old Feb 6, 2005 | 02:09 PM
AdamsssEvo's Avatar
Would an evo with 31000 miles need an ugraded valve train if hks264/264 put in?
Is that too high of mileage to just swap cams?
Old Feb 6, 2005 | 02:13 PM
jsprat7's Avatar
i doubt it. im thinking of cams also with 33000 on mine.
Old Feb 7, 2005 | 03:10 AM
trinydex's Avatar
at first the rave was yes... then people found out... i don't need to do that. do look up cam installs tho and bleed the lifters and what not and get someone that knows what they're doing.
Old Feb 7, 2005 | 04:44 AM
Zeus's Avatar
Actually there is still some question... David Buschur (who I probably respect over all others) says "no". However, Revolver has posted pictures of why you would need to (showing pictures of actual retainer to seal contact) in another thread.
Old Feb 7, 2005 | 04:45 AM
Jadiem's Avatar
yes... i recently cracked my 4th piston and floated all my valves... i had hks 264's and cam gears installed a week before..
Old Feb 7, 2005 | 05:38 AM
JustDSM's Avatar
With the pics you mentioned, were the HKS cams installed or Revolver's?
Old Feb 7, 2005 | 05:42 AM
EVOTEXAS's Avatar
At what RPM?
Old Feb 7, 2005 | 06:10 AM
Zeus's Avatar
HKS 264's on the flow bench, with a keeper spring showing contact with the seal prior to max lift... You need to read this thread: https://www.evolutionm.net/forums/sh...r+seal+contact
I'm personally running 272's on OE springs and retainers... however, after reading the above thread, and not finding the answer I want, I'm going with the Revolver set. If for nothing else, it will not hurt, and I will have more "headroom" to spin the engine up if I choose.
Old Feb 7, 2005 | 07:20 AM
PVD04's Avatar
I'm curious as to what your cam gear settings were when this happened. I have not seen another incident like this, and would like to know a little more about how it happened before I do a cam upgrade.
Paul
Old Feb 7, 2005 | 07:23 AM
Curt@MrLed's Avatar
Former Vendor
same goes for me^^^^
Old Feb 7, 2005 | 07:55 AM
Jadiem's Avatar
i had HKS cam gears set at -2 on both sides... i got these numbers from Vishnu..
they are telling me that i "over reved" the motor, but i've never been past 7500 rpm (i usually shift at 7k) ... it blew on me in 2nd gear around 5k...
cost of repairs = $1500.... if i could have done it all over again i would upgrade the entire valvetrain and go with a Cometic headgasket, probably port the head since it would be off the car...
edit: i had 12,400 miles on the car
Old Mar 10, 2005 | 09:17 AM
WildRice's Avatar
The safe play is to upgrade. I have no clear idea of what the problem is with clearances but there seems to be one on certain heads but not on others. I guess its like Dirty Harry's line "Do you feel lucky?" If revs are to remain under 8k then the only necessary reason to upgrade would be to ensure that retainer to seal conatact will not take place. It is would be good practice to get a test spring and actually check for clearances. Since I ruined a new engine, I am not comfortable with pushing limits which put me at risk for thousands to save hundreds.
HKSevolutionNYC
Feb 9, 2016 11:12 AM
Dr3zA
Aug 29, 2015 08:40 PM
Werd
10
Jun 29, 2009 04:05 PM
redlinedrift
Jun 23, 2008 04:57 PM
RUN FOREST RUN
18
Jun 16, 2008 06:33 PM
