AEM EMS Get tuning help for your AEM EMS system.
2 step help~
Old Jun 25, 2006 | 03:38 PM
BANKS 2's Avatar
2 step help~
can someone tell me how to set up the 2step rev limiter?
what settings do i put in , if i want it to rev to 5k?
i seen there is a mph, vss, rpm fuel cut, rpm ignition cut, etc
thanks!!!!!!!!
Old Jun 25, 2006 | 06:23 PM
evolved4g63's Avatar
Try 10/ hard cut in params. Then options. ign cut 5000. Fuel cut 6000. If you want to build a few pounds of boost use the ign retard. Start at like 4950. The lower you go with this rpm the more boost you will build. Vss 10. The launch control will work under this mph.
Old Jun 25, 2006 | 07:07 PM
Kerr's Avatar
Fomer Vendor
Do you have to wire some sorta switch to make the launch control work? Or is there another way without installing or wiring something?
Old Jun 25, 2006 | 08:13 PM
If you use the vss in the 2 step setup there is no need to wire anything. If you want a no lift to shift setup, you will need to run a wire from the clutch switch.
Old Jun 27, 2006 | 05:21 PM
BANKS 2's Avatar
ok i just tried what you said:
getting tons of backfires, and it didnt really build boost... is that normal?
what do i set it to? Always ON? VSS? theres about 15 to choose from.
Old Jun 28, 2006 | 04:17 AM
Always on.!!
The vehicle speed sensor is what your using to activate launch control. Under 10mph it activates. If you want more boost lower the retard rev rpm's in50 rpm increments. Test, and adjust to your setup.
For my 35r setup i was doing ign cut 6000, fuel cut 7000, retard rev 5750. That got me around 10- 14 psi off the line.
Old Jun 29, 2006 | 02:31 PM
BANKS 2's Avatar
ok .. i think that i didnt put on the hard cut.
Old Apr 20, 2008 | 12:32 AM
Johnboy1065's Avatar
on mine all of the rpm's for all the options cut out at 6000
Old Apr 27, 2008 | 07:49 PM
fre's Avatar
fre
Yea I am running E85.
As far as the switch setting goes, as mentioned above set it to always on and use the speed sensor to activate it. I am running 10/ hard cut on both my main and 2 step limiters.
Fuel cut 1k higher than ignition cut = backfires like crazy, worried about fouling plugs.
Fuel cut 1k higher than ignition cut, but only part throttle = no backfires and A/F around cruising range, which for me on E85 is 15.7-16:1 ish. (this is what I chose to leave it on).
Fuel cut same rpm as ignition cut = no backfires, but running lean on the 2 step which makes sense. I am not sure if this is bad or not since their really isn't much load to speak of, so I chose the above option for safety reasons.
Tried anti lag once, but I don't like the idea of extra fuel exploding inside my turbine housing. My clutch slipping seems to build boost just as well, although probably not as fast. I will just have to settle for 1.7 60's at best
Old Dec 10, 2009 | 01:52 PM
myevo8you's Avatar
yes
lancerMXV6
Aug 20, 2013 08:06 PM
Jamessvt2004
AEM EMS
26
Jul 5, 2012 10:12 PM
wizzo 8
Apr 21, 2012 06:53 AM
audiofan
Apr 3, 2011 05:36 PM
