AEM EMS Get tuning help for your AEM EMS system.
2step didn't work, what did I do wrong?
Old Jul 12, 2006 | 03:36 PM
Kerr's Avatar
Fomer Vendor
So I tried it, got the info from Banks thread, but it didn't work. I changed the fields in the Options - 2step rev limit to:
input: switch is always on
fuel cut: 6000
ignition cut: 5000
OK below vss: 5
retard rev: 4950
I only got to test 2 times, once was in neutral with the clutch out, ebrake on, and in 1st gear, clutch in, ebrake on. Will that make it not work, the ebrake? It is with a friends laptop and I was at his house, it was loud so I stoped, with only the 2 tries.
The other thing I wanted to try was changing the input to V speed on. And where is the hard cut option at, I can't find it.
And do you have to change the fields to match in the Options- Main R... window?
Thanks
Old Jul 12, 2006 | 07:01 PM
8URVTEC's Avatar
As far as I know, you have to have the car in gear at below the set mph. Or better yet from a dead stop, clutch in with 1st gear then step on the accelerator till it starts to bounce off the rev-limiter (making boost) Then side step or dump the clutch. Mine backfires quite a bit and makes about 12 psi of boost off the line.
Old Jul 12, 2006 | 07:04 PM
DCSilvrEvo's Avatar
Please dont side step(dump) that will have you breakin tranny parts!!!!!
Old Jul 12, 2006 | 07:08 PM
8URVTEC's Avatar
fuel cut: 6000
ignition cut: 5000
OK below vss: 5
retard rev: 4950
Thanks
Here are my settings:
input: switch #2 Gnd=On
fuel cut: 5700
ignition cut: 5500
OK below vss: 1
retard rev: 12000
And my Main Rev-limit is:
Fuel Cut 8100
Ignition Cut 7900
Fuel Cut Load 35.12
Retard Limit Rev 12000
Hope this helps, it works for me!!!!!!!!
Old Jul 12, 2006 | 07:29 PM
Knightracer's Avatar
fuel cut: 6500
ignition cut: 6500
OK below vss: 5
retard rev: 6500
Thats what mine is and it works like a charm.
Old Jul 12, 2006 | 07:31 PM
saiyanzzrage's Avatar
i dont know if its like al (dynoflash) 2-step, but i noticed if the car is not COMPLETELY stationary, it wont work
the car needs to be completely stopped..any sort of roll and it doesnt work, the rpms will shoot to redline. My buddy's evo which was tuned by AL is the same way
Old Jul 12, 2006 | 10:57 PM
8URVTEC's Avatar
How do you do it, do you still slip it?
Old Jul 13, 2006 | 12:19 AM
Warrtalon's Avatar
Yes, slight slip until it removes the drivetrain slack, then quickly release the clutch. Keep your foot on the gas pedal the whole time.
Old Jul 13, 2006 | 09:26 AM
Kerr's Avatar
Fomer Vendor
I was dead stoped and had the E brake on. I wasn't flooring it, or even at half throttle, maybe a quarter, will that affect it. Do the settings I have look correct in that it "should" be working?
And thanks for all the replys
Old Jul 16, 2006 | 06:47 PM
Kerr's Avatar
Fomer Vendor
Ok, I was thinking about it, I have an 03, so there is no factory 2-step. Now how does the factory 2-step work? Is it off a switch and thats why everyone said the setting should be "switch always on". Or should mine be "V speed on" since thats how I would have to do it?
Or with my settings should it be working???
Old Jul 19, 2006 | 05:18 AM
8URVTEC's Avatar
Mine is switch #2 gnd on! You need to turn a switch on in the aem two step settings.
Old Jul 19, 2006 | 06:57 AM
forbidden color's Avatar
try this setting.
fuel cut: 6000 <---change to 5100
ignition cut: 5000
OK below vss: 5
retard rev: 4950<---change to 12000
maybe it'll work for you.
Old Jul 29, 2006 | 07:51 AM
Inn-Tune's Avatar
If you set the input as switch is always on there are no mechanical switches that must be tripped. No clutch switch, no in gear indicator, etc. If you're under the VSS you set the 2 step will be on.
Unless you understand what retard rev does and you're sure you want to use it, set it to 12000 as others have mentioned.
evodude32
Apr 9, 2016 12:01 AM
REV-X
Mid-Atlantic Region
Apr 28, 2011 06:29 PM
raytrix
Jun 23, 2008 02:44 PM
Forrest Gump 9
Dec 28, 2007 03:21 PM
1NastyEvo
Dec 26, 2005 11:10 PM
