AEM EMS Get tuning help for your AEM EMS system.
logging paremeter's
Old Nov 9, 2006 | 02:39 PM
steelcityevo8's Avatar
logging paremeter's
i have made a few logs on the laptop and tried to change the paremeter's of the log. i currently cannot view knock figures at all on the current log. i went to graph setup and scrolled thru the paremeter options and knock is not an option anywhere. what and how do i get it into one of the options for the log. Any help will be greatly appreciated
Old Nov 9, 2006 | 02:48 PM
kcevo's Avatar
What is logged is dependent on what Parameters window you have displayed in AEM Pro while logging via the laptop. If your viewing the Egine Start parameters screen and logging in AEM Pro, then those are the only parameters you can choose from in the AEM LOG drop down box.
Old Nov 9, 2006 | 02:51 PM
ryan0's Avatar
what he said.
just open a paramaters window.. unlock it.. add in what you want to log.. and save it as a template.
then when you want to log stuff, just click the template button and hit f6.
ok so how do i change the window and what is being displayed
Old Nov 9, 2006 | 02:54 PM
ryan0's Avatar
close all the windows.
view -> parameters.
add fields you want
lock
templates - > save.
add the button.
done.
Old Nov 9, 2006 | 02:57 PM
ok cool appreciate it . can i set this up offline
Old Nov 9, 2006 | 02:59 PM
kcevo's Avatar
The icons that run along the top of the screen are shortcuts to various windows of the AEM software along with the parameters for those tuning options, IE Engine Start, Fuel, Ignition, Tuning, etc. These are the default parameters that AEM has suggested are best to be viewed while tuning this area of the AEM software. You can choose like Ryan said to unlock the parameters window and add/subtract parameters to view.
ryan0's Avatar
yup.
Old Nov 9, 2006 | 03:00 PM
kcevo's Avatar
Yes you can set it up offline.
Old Nov 9, 2006 | 03:06 PM
just hooked it up fellas thanks a million
Old Nov 9, 2006 | 03:12 PM
as long as that paremeter window is up and viewing data that is what will get logged correct??
Old Nov 9, 2006 | 03:29 PM
ryan0's Avatar
yup
jakgal04
Mar 28, 2016 08:16 AM
nj1266
May 28, 2009 10:05 AM
voltexct9a
May 22, 2009 08:18 PM
acamus
Oct 24, 2008 06:22 AM
BigBallin
Aug 11, 2007 07:17 AM
