AEM EMS Get tuning help for your AEM EMS system.
Need help, swapped out AEM EMS to stock ECU, now throwing codes!!!!
Old May 21, 2007 | 07:56 PM
matyb's Avatar
if the only fault you have left is the p0172 i would have to say it is from the fuel pump, if all your other mods are removed.
Old May 21, 2007 | 08:01 PM
Blue Evo 8's Avatar
Thats a good theory, but I spoke to AMS and a few other shops and they told me that it is unlikely....
but one can also argue that the high pressure FP is pushing way too much fuel, therefore causing the rich condition... I dunno....
Old May 22, 2007 | 04:31 PM
matyb's Avatar
AMS or what ever tuner/shops that you talked to may know more about your current situation, if all things on your car are stock and you have a 255 in it i can almost be 100% sure that is your problem.
note: you called it a high pressure pump, its not a high pressure pump at all just a high volume pump. the fuel pressure regulator regulates pressure hence the name . if it is able to do its job properly with that pump installed is the question??? swap pumps its easy enough and stop theorizing
Old May 22, 2007 | 05:51 PM
Blue Evo 8's Avatar
Thanks, I think I might have solved the problem, the intake cam setting was not set at 0,0 as it was set at +2 int, 0 exhaust......
I did this setting and ran the car for 10 minutes till it warmed up and had no codes.......
Old May 23, 2007 | 08:15 PM
SLO-EVO's Avatar
Originally Posted by bluebyu36
come to long island i can get you passed
with and all your mods.........
and codes............and your bald tires
LMAO you aint lieing... ive seen the worst cars pass inspections there
I pulled my plugs and this is what it looks like......
definately running rich.... now what??
open your fuel maps and tone down your fuel maps
Old May 23, 2007 | 08:28 PM
Blue Evo 8's Avatar
Looks like I'm gonna have to have someone flash my ECU with different fuel maps to I can pass and not throw this damn P0172 code....
Old Jun 7, 2007 | 06:07 PM
Blue Evo 8's Avatar
EDIT:
I found out that the HKS 280's were causing the P0172 code to appear. basically I had to put the car back to stock, i.e. stock ECU, injectors, MAF, stock cams, stock Fuel pump in order to pass.....
Once all the codes disappeared for good, it took me about 10-15 miles of highway driving at moderate speeds to get all the ECU "monitors" into a ready state.
It does pay to have an OBD2 tester on hand
I went for inspection today and passed:
I'll be converting back to EMS once I return from vacation ....and more go fast goodies will be going on once I return.
awdordie
Jun 15, 2017 10:00 AM
Nic Money
Mar 22, 2012 12:20 AM
dudemeister
Lancer Troubleshooting
Jan 18, 2011 10:51 PM
BadazzCR
Aug 23, 2008 07:40 AM
Blue Evo 8
22
Jun 8, 2007 08:42 PM
