AEM EMS Get tuning help for your AEM EMS system.
Ems Drivability Question!!!
Old Jan 15, 2008 | 10:26 AM
dafunk630's Avatar
hey guys,
alright i have not been all that happy with my EMS. I do not know if its because of the bad tune that i have or what... Drivability is not that great on my car, like for example cruising at low rpms, the idle of my car is horrible and the common issue COLD START!! So my question is with a good tune from a good tuner is it suppost to drive like a stock ecu car??? because if it is, then i would have to look for a different tuner!! please guys help me out with this problem!!!!
-thanks
Old Jan 15, 2008 | 10:41 AM
Johnboy1065's Avatar
Originally Posted by dafunk630
hey guys,
-thanks
mine drives almost like a stock car as far as cruising at low rpm's. my idle is higher than stock. the car does not drive good until it has warmed all the way up though. But other than that it drives good with the AEM EMS.
Old Jan 15, 2008 | 10:44 AM
dafunk630's Avatar
who tuned your car??
Old Jan 15, 2008 | 10:45 AM
Nez136's Avatar
Same here. Martin tuned my car and it runs perfect. My only issue is the cold start below 40* but im ok with it.
Old Jan 15, 2008 | 11:57 AM
AlohaEvo's Avatar
other than starting my car (I have no IAC) my car drives fine
Old Jan 15, 2008 | 01:45 PM
GTVEVO's Avatar
Get a different tuner, I have been running the EMS for almost 3 years and still learning stuff about it. I have also seen some of the tunes on peoples cars from shops and I was honestly stunned, I don't see how some people put up with it. So the best words of advice are to either learn the system and do it yourself or find someone who you can trust do provide a good tune. A good tune cannot be done in a couple hours and be 100% exact with the EMS.
Old Jan 15, 2008 | 02:38 PM
David Buschur.
Old Jan 15, 2008 | 03:58 PM
GTVEVO's Avatar
David Buschur.
That explains it, it will probably make some good peak power though.
Old Jan 15, 2008 | 04:03 PM
vboy425's Avatar
that's why i hate AEM. Autronic FTW
Old Jan 15, 2008 | 04:13 PM
turboDan's Avatar
David Buschur.
That is incorrect info. I do know the name of the shop that did his tune and it was Not Buschur.
Old Jan 15, 2008 | 06:09 PM
dafunk630's Avatar
SO WHEN CAN U START WORKING ON MY CAR DAN???
Old Jan 15, 2008 | 10:28 PM
what??? Dafunk asked me who it was that tuned MY car. I'm pretty sure I remember it being David Buschur lol
Old Jan 15, 2008 | 10:34 PM
Lucas English's Avatar
With the right tuner the AEM can drive and run better then stock.
Find a better tuner.
Old Jan 16, 2008 | 05:21 AM
turboDan's Avatar
My bad ,I thought that the question was who tuned Dafunk630's car and I know who it was and it was not David.Now after reading your post it makes sense . Ray,you just need to get it tuned properly and you will be much happier with the AEM as a bad tune will make you want to throw the AEM out the window like so many do when it is not tuned properly.Get a good tuner to tune it and you will make alot more power than the place that tuned it originally for you and it will be much nicer to drive
Old Jan 16, 2008 | 07:55 AM
dafunk630's Avatar
WHO DO U RECOMMEND??? IVEY IS NOT TUNNING AEM EMS ANYMORE...
