AEM EMS Get tuning help for your AEM EMS system.
where is the ecu ground wire terminated?
Old Mar 15, 2008 | 02:25 PM
Aby@MIL.SPEC's Avatar
i was wondering where the oem ecu ground wire, pin#13, terminated on the car?
i want to have my wideband gauge ground wire terminated @ the same location.
TIA
Old Mar 17, 2008 | 07:12 AM
joeracer321's Avatar
I believe it is terminated behind the passenger side kick panel and up a bit, about half way up the glove box height if I remember properly.
Old Mar 22, 2008 | 06:24 PM
^ i crawled under the dash & saw 2 black wires with gold dots going to through the firewall & being terminated in front of the battery on the drivers side.....along with a bunch of other ground wires.
i am refering to ecu pin #'s 13 & 26. per aem, they are ecu ground wires.
i want to ground my aem uego to the same point as the ecu, in attempts to alleviate a discrepancy between what the uego say's & what is observed within logged data.
Old Mar 22, 2008 | 06:50 PM
That is what the 02 gain is for. Again look on the passenger side there is a ground point where a few wires terminate, I believe that is the ecu ground.
Old Mar 23, 2008 | 10:46 PM
i know, but sometime the 2 are bang on & oher times the gauge & ecu are ~0.2-0.4 different not something i care for while tuning on 91 octane.
i will. but according to aem, the 2 ecu ground wires are pin 13 & 26. i followed those wires to the grounding area near the battery. i will look again for the wires your describing...
Old Mar 30, 2008 | 06:44 PM
according to the aem wiring .pdf, the ecu ground wires are #13 & #26 = black with a gold dot.
i did find wires in the kick-panel area, however they are black with silver dots.....i didnt find any black wires with silver dots coming out of the ecu?
Old Sep 7, 2017 | 01:56 AM
2rbolag's Avatar
So just tap ground pins 13 & 26 from ECU to wb for ground?
Old Sep 29, 2018 | 02:22 PM
Evo_Jay's Avatar
To answer this for people in the future, The ECU grounds (pin 13 and 26) terminate at grounding location #4, which is the grounding location behind the battery on the side of the strut tower.
Bladey
Dec 27, 2017 12:46 PM
lancer02Josh
Lancer Troubleshooting
Aug 29, 2017 06:50 PM
Waferz
Mar 14, 2017 01:00 PM
TxFAkuma
13
Jun 22, 2016 08:53 AM
EvokidIX
Mar 12, 2016 04:08 PM
