AEM EMS Get tuning help for your AEM EMS system.
Fuel table question - EMS
Old Jun 7, 2008 | 11:30 AM
Street gear's Avatar
Hi I am a newbie to the ems thing anyways I was looking at my base tune fuel table. When I view it in the duty cycle mode I noticed some cells in the high RPM and Map reading is over 100. Can anyone explain to me why that is the case? I thought there is no value going over 100.
Old Jun 8, 2008 | 04:17 PM
tseitz123's Avatar
Did you set up your injectors correctly?
Old Jun 10, 2008 | 11:01 PM
I talked to the guy who originally setup the tune. It is the correct injector setup apparently in the area on the table showing above 100% duty cycle is for areas I am not currently using, 7500-8000 above 30lbs of boost. I am only running 27 right now so he said he didn't pay much attention to those areas. I believe I was correct when I said there is no value going above 100%. If one has to go that high then the injectors is too small.
Old Jun 24, 2008 | 04:19 PM
crewdawg130's Avatar
you need injectors. That number will go as high as it can. its just math based on your injector selection
Old Aug 30, 2008 | 12:12 PM
awdboosted's Avatar
The numbers on the fuel map are not injector duty. You need to log it.
Old Sep 1, 2008 | 02:00 AM
kjewer1's Avatar
Well, technically they are injector duty, but a more appropriate term would be target injector duty. There are other modifiers that will change the outcome, boost comp being the biggest.
Dynotech Tuning
Sep 20, 2016 01:30 PM
PPM
Apr 2, 2015 09:35 AM
Street gear
Feb 28, 2010 06:23 PM
loppad
AEM EMS
Oct 7, 2008 12:18 PM
