AEM EMS Get tuning help for your AEM EMS system.
AEM EMS and turbo timer
Old May 8, 2009 | 06:27 AM
El Boricua's Avatar
Hey, since we installed the AEM EMS, the turbo timer is acting kind of funny. Every time after I start the car, the turbo timer resets and starts the the countdown.
BTW, it is a Greddy Turbo Timer ...
Another thing is that after a couple of minutes of the engine been on, I hear a click and then the turbo timer resets again..
Have someone else experience this behavior...?
Does it has to do with the wiring..? or the signals from the EMS..?
Any comments will be appreciated..
Thanks,
Old May 8, 2009 | 02:09 PM
awdboosted's Avatar
I would personal ditch the Turbo timer.. They are a waste of gas and do nothing for the car. You can also set up the AEM to act as a turbo timer
Old May 9, 2009 | 03:04 PM
El Boricua's Avatar
How you do that..??
Old May 9, 2009 | 06:25 PM
czilla's Avatar
i would like to know that to
Old May 11, 2009 | 01:47 PM
awdboosted's Avatar
When I get home I'll look at the software and give you the menu..
Old May 11, 2009 | 01:51 PM
El Boricua's Avatar
That would be great...
Thanks,
Old May 11, 2009 | 07:44 PM
awdboosted's Avatar
I was told the wrong thing a few years back Like 3 years ago... Never tried it until now. Its under: setup/advance set up/ main relay control/ option - main relay/ Then main relay stop eng.
Sorry.. It doesn't work.
Old May 12, 2009 | 05:06 AM
El Boricua's Avatar
oohh... thanks...!!
Well still looking to see what's wrong with the interaction between the turbo timer and the AEM EMS...!!
Old May 12, 2009 | 10:24 AM
awdboosted's Avatar
Originally Posted by El Boricua
oohh... thanks...!!
I think that the Turbo Timer work with the key. I don't think the EMS has anything to do with it. Try plug up the stock ecu and seeing if it does the same thing.
Old May 12, 2009 | 03:17 PM
project_skyline's Avatar
Sounds like its not wired right or something in your ignition system is messed up.
But its definitely not an AEM caused issue.
Old May 12, 2009 | 04:10 PM
El Boricua's Avatar
Everything started when we installed the EMS.. it is not happening with the stock ECU...!!
Old May 22, 2009 | 02:35 PM
awdboosted's Avatar
Try and extent the time the main relay stays on. See if that helps.
Old May 22, 2009 | 04:26 PM
El Boricua's Avatar
Then again... how you do that..?
Thanks,
boostin@27
14
Jan 8, 2014 05:11 PM
gudmundur
11
Jul 19, 2008 01:21 PM
jojipoji
Apr 19, 2008 06:10 AM
evobullet
Apr 1, 2008 09:04 PM
vr4_211
Dec 4, 2005 09:22 PM
