turbo timer issue... HELP!!!
Old Sep 5, 2007 | 12:18 PM
boostin@27's Avatar
im having an issue with my greddy turbo timer. recently my battery got disconnected somehow, so i put the battery terminal back on and car started up again, no problem. but now my turbo timer isnt working and it shows some wierd symbol or number when its on, and none of the buttons are working but its on its just showing this... 0_0, or something very close to that on the sceen. i tried to reset it but it wouldnt work, since none of the buttons are working except on/off. i really need your help on this.
thanks
Old Sep 5, 2007 | 06:29 PM
JDMCT9MR's Avatar
Did you check all of the wiring on the T/T?
Old Sep 6, 2007 | 11:52 AM
boostin@27's Avatar
yes it seems to be plugged in. i think it might be running to low a circuit and not be getting enough power to have the TT work correctly. please keep helping me though
Old Sep 7, 2007 | 11:01 AM
boostin@27's Avatar
please help me out guys!!!
Old Sep 7, 2007 | 11:02 AM
boomn29's Avatar
Verify the ground is solid?
Old Sep 7, 2007 | 02:34 PM
nyaegermeister's Avatar
if you have the harness unplug it and plug it back in. if that doesn't work check to make sure it has a good ground. if that doesnt work you could have burnt up the components in the TT casing somehow.
Old Sep 7, 2007 | 02:37 PM
suekie's Avatar
did you try and contact greddy and ask them??
Old Sep 12, 2007 | 12:38 PM
boostin@27's Avatar
what do you mean by the ground? im not very good with this stuff...
Old Sep 12, 2007 | 12:39 PM
sikrsix's Avatar
The black wire.. Try disconnecting and wait 5 min, then plug it back in like another member above said.
Old Jan 7, 2014 | 09:21 AM
ptm5070's Avatar
any answers yet? i have the EXACT same issue, battery got unplugged during my clutch install now the timer just says 0_0.... doesn't work at all..... help!
Old Jan 7, 2014 | 10:45 AM
szodjo's Avatar
A search for 'Greddy turbo timer error codes' reveals a bunch of threads at other forums with people asking the same question though I couldn't find any with an answer.
Wasn't able to find anything in the manual but you should re-check all your wiring to ensure it is to spec: http://greddy.com/upload/file/FATT.pdf
If that doesn't work, email tech@greddy.com.
Old Jan 8, 2014 | 09:21 AM
ptm5070's Avatar
Well.... I didn't find any info on error codes, but I found somebody with the same issue with a Volvo and said they fixed it by holding the p and the s buttons, or the p and the t..... here's a link
http://volvospeed.com/vs_forum/topic...o-timer-error/
Gonna try this when I get home.
Old Jan 8, 2014 | 09:40 AM
06MREvo's Avatar
Serious?! This thread is over 6 yrs old!!
Old Jan 8, 2014 | 10:57 AM
ptm5070's Avatar
well I brought it back to life rather than posting a new thread then having somebody just tell me to look it up myself....
Old Jan 8, 2014 | 05:11 PM
ptm5070's Avatar
UPDATE: Put a new battery in and the turbo timer worked perfectly! The old battery didn't have enough juice or a good enough connection to power the turbo timer to work right! I know it's strange but it works now!
benIX
Aug 24, 2014 03:53 AM
740 Turbo Brick
May 7, 2014 05:37 PM
ptm5070
Jan 8, 2014 01:47 PM
antwon6420
Sep 7, 2009 05:55 PM
CatalystIX
Feb 12, 2008 06:53 PM
