AEM EMS Get tuning help for your AEM EMS system.
Who has tried Series2?
Old Aug 1, 2010 | 12:33 PM
  #76
Tbtalon94's Avatar
Originally Posted by itzwolf
Did he say what is causing it? I'm hoping its a fix over all rpms cause its obvious in the above picture its happening elsewhere.
He just told me that they have found the issue and are working to fix it. Didn't really tell me what it was. I've noticed slight misses in other areas but not near as bad as right at 2,100. It's horrible. Feels like I'm hitting fuel cut.
Old Aug 2, 2010 | 10:57 AM
  #77
itzwolf's Avatar
Guess I'll have to wait. I had to send the unit in for the resistor replacement and full checkup due to all my issues. They received it last week on Thursday or Friday so I am eagerly awaiting something...
Old Aug 2, 2010 | 01:48 PM
  #78
MitsuJoe's Avatar
I am curious if my unit is new in the box if I should just send it in. My supplier told me that not one of these units have worked properly out of the box. Guess I will be holding on to my Series 1 for a while longer....
Old Aug 5, 2010 | 12:47 PM
  #79
churchja's Avatar
Per the AEM Forums, "Monday the 9th is our current target." for the next firmware update.
Old Aug 9, 2010 | 05:44 PM
  #80
Tbtalon94's Avatar
So much for that update....
Old Aug 9, 2010 | 06:00 PM
  #81
churchja's Avatar
Unreal... AEM is really beginning to p!ss me off! A couple months ago it was a couple of weeks for the update... A couple of weeks ago it was a few days for the update. And now today was the projected update release date... no update!
AEM WTF over?
Old Aug 9, 2010 | 06:15 PM
  #82
itzwolf's Avatar
I've been told they are very busy by one of the techs. I never got my tracking number for my Series 2 return so I am in the dark when it's actually coming and no email communication for the past several business days
Frustrating...
Old Aug 9, 2010 | 08:18 PM
  #83
churchja's Avatar
They did it... Just checked the AEM Forums... AEMTuner 2.0 and firmware 1.17 is available for download...
Quick summary:
1. Improved AEM Tuner Menus and Workspace Layout
2. Mitsubishi Quick Start (01v17 firmware)
3. Better Idle Control (01v17 firmware)
4. Improved Mass Airflow Strategy (01v17 firmware)
5. Better Knock Control (01v17 firmware)
6. Serial Telemetry broadcast (01v17 firmware)
7. Improved Rev Limiters (01v17 firmware)
8. Simplified Dwell Control (01v17 firmware)
AEMTuner V2.0 – Improvements since V1.91:
- Improved Auto Display Layout feature.
- 2D table header column width now stored in workspace.
- Improved control when resizing 2D or 3D displays.
- Added menu item to show current workspace name.
- Reorganized “File” menu to minimize mouse clicking for frequently used tasks.
- Improved algorithm to access calibration 2D/3D table more efficiently.
- Option displays now compatible with hex format options.
- Smart table conversion added to minimize the number of items users must update in their calibration file when converting to firmware version 01V17.
- Fixed bug that caused the “+” key to make a beeping sound.
- If the scrollbar was visible, displays sometimes would not snap to grid when moved. This is now fixed.
- Fixed bug that kept options table display layout preferences from being saved in workspace.
- 2D/3D Display split information is now stored in workspace.
- Fixed bug that caused an error when displaying Series 1 EMS v1.19 calibrations. Note: AEMTuner is not 100% compatible with Series 1 EMS hardware.
- Fixed injector and coil phasing options display bug.
- Menu items "save workspace" and "save calibration” now disabled when workspace or calibration is not modified.
Firmware 01V17 – Improvements:
- Quick start feature improved for Mitsubishi, 1G/2G and EVO8/9.
- Fixed bug causing inconsistent idle behavior on vehicles using stepper motor type idle control valves. These include all Toyota and Mitsubishi applications.
- Fixed cranking mode bug that caused inconsistent injector firing.
- Fixed boost target displays for proper function with units of psi.
- Fixed vehicle speed calculation error if VSS Smooth and/or VSS Filter options enabled.
- Improved the knock control algorithm.
- Fixed bug causing an inconsistent tachometer output function.
- Fixed EGT channel display bug.
- Improved the switched retard function.
- Shortened startup time for serial telemetry broadcasting.
- Fixed bug in the Ignition trim vs start time table.
- General improvement in all Engine Rev Limiter functions.
- Initial crank pulse and battery offset trim tables now use milliseconds instead of microseconds.
- Simplified the ignition coil dwell control algorithm to make it more intuitive.
- Improved Mass Airflow control strategy.
- Improved staged injection algorithm.
Old Aug 10, 2010 | 12:28 AM
  #84
churchja's Avatar
Ok another update.
My misfires and hesitation issues are being investigated by the engineers. I was able to catch some really severe cutouts around 2000 and 2100 rpms while holding a stead pace no acceleration or throttle movements whatsoever. It's not just there that it happens but that was extremely obvious to them and now its being looked at.
Wolf,
I was having similar hesitation issues (2,000 - 3,300 RPM)... maybe too soon, but 1v17 seems to have resolved my issues. Have you had a chance to assess?
Has anyone noticed if the idle motor parking issue has been resolved? Still to early for me to say yes or no. But initially, I want to say start ups are better with 1v17.
Thanks,
J. Church
Old Aug 10, 2010 | 05:37 AM
  #85
itzwolf's Avatar
Originally Posted by churchja
Wolf,
Thanks,
J. Church
I am still waiting on my Series 2 to get delivered. I was supposed to get a tracking number last week and never received it. I know they have been busy so I haven't made a stink about it.
I was running an internal release of firmware v16 for several days before I sent it in for other issues (wrong resistor on the coolant circuit) and the misfires. Startups were greatly improved to maybe 1 in 15 starts it wasn't the first try. It did have a slight sluggish kick over on the actual fire at times on the initial hit but it started almost every time. I reported this so hopefully they fixed that or maybe it was a slight fueling issue.
Idle issues were resolved with the v16 also so it caught idle all the time. I purposely tried to get it to screw up a few times and it wouldn't.
Having played with Series 2 for a while on Evo's and been tuning it on 2 Supra's lately had be on a quest to dial my Series 1 in even better and I actually improved the startups considerably but it still can't touch the instant start of Series 2.
I hope to have answers this week sometime!
Old Aug 10, 2010 | 06:15 AM
  #86
Tbtalon94's Avatar
I will be updating my firmware from the internal release of v16 that itzwolf and myself had to v17 and report back if the issues I had are gone.
The new firmware should make EVERYONE's start/idle exceptionally better. The ecu will now sync before engine RPMS are seen. Before it took 2 revolutions for the ecu to start syncing but now as long as the ignition is on it will try to sync, once it see's revolutions it will stat sync and fire right up. It usually takes my car around 1.5-2 revolutions to fire, instead of the 4-6 it took series 1.
Old Aug 10, 2010 | 09:29 AM
  #87
itzwolf's Avatar
Looking forward to your comments on the new firmware.
Old Aug 10, 2010 | 10:51 AM
  #88
Tbtalon94's Avatar
Well so far so good. After I updated it I tried to start it and it fired then died, after a few quick checks over a few of my tables were zero'ed out. I'm blaming that on not having a proper update script from v16 to v17.
My 2,100rpm miss seams to be completely gone. I drove around for a bit and tried to make it happen and it wouldn't. Starts seam to be consistent and the idle is good. Overall i'm pleased.
Only one issue. If you get into the Output Options and try to close it an error pops up and you have to manually close out of AEM (through ctl+alt+dlt) because it gets stuck.
-Trevor
Old Aug 10, 2010 | 11:17 AM
  #89
itzwolf's Avatar
-Trevor
Ahh no script from v16 thats why, I converted my v14 and merged the changes form v16 into the v17 cal. All other calibrations were only v14 (Supras) so I didnt experience any table issues.
The misfire issue is very pleasing to hear! What about above 2100 and in the 3000 to 3300 range?
The Outputs issue I commented on AEM forums:
"I haven't connected to an ECU yet but the Outputs menu doesn't give me a problem opening it just to look at it. Were you connected to the ECU when this happened? I wont be able to test any Series 2 connections until earliest tomorrow on one of the Supra's I tune unless my box happens to be delivered today..."
Did you uninstall AEMTuner then install or install over the old version? I uninstalled and started from scratch again. Still working on the workspace changes I like...
Old Aug 10, 2010 | 12:10 PM
  #90
Tbtalon94's Avatar
I was connected at the time. It doesn't seam to do it when not connected.
