AEM EMS Get tuning help for your AEM EMS system.
AEM and check engine light?
Old May 4, 2010 | 09:47 AM
travail's Avatar
If you are using the AEM pcm set up will you still get a check engine light if there is some thing wrong?
Old May 4, 2010 | 06:52 PM
MR Turco's Avatar
Can only bump once a day.
Old May 5, 2010 | 06:59 PM
mike 99gsx's Avatar
It depends on what your definition of "something wrong" is. You can set up a low or high side driver to trigger the light to come on based on certain conditions but its usage is a little limited.
Old May 6, 2010 | 12:20 PM
browningderek's Avatar
the check engine light in plug and play for the shift light. setup/ advanced/shift light.
Old May 15, 2010 | 07:59 AM
SkipDMan's Avatar
You can setup the CEL to display in certain warning conditions.
Lean under WOT
Coolant temp high
Overboost
You have to manipulate the Configurable Output settings.
Old Jun 4, 2010 | 09:00 AM
GRNMCH's Avatar
In other words, you live and die with how set-up your AMS EMS. The factory CE light functionality is gone! So how do you tell that something is wrong? You now have to know and understand how things work and what they are supposed to do when everything is fine, in order to recognize a problem…
Old Aug 17, 2010 | 12:13 PM
mtxfrk2k1's Avatar
i had a similar problem when i bought my evo the other day. everytime i touched 7k my check engine light would blink. finally figured out it was a shift light
Old Aug 29, 2010 | 05:05 PM
bong pantaleon's Avatar
i will be using my check engine light to show that i switched my map settings to race gas set up.
Old May 10, 2013 | 05:47 PM
foxbear2277's Avatar
sorry to dig up a old thread... but this scared me ****less today
tunermt
AEM EMS
44
Dec 13, 2025 12:46 AM
deadstockkpomp
Aug 17, 2018 01:13 PM
seven10
Sep 18, 2015 03:49 PM
butters149
Feb 8, 2014 02:17 PM
GSX 911
Aug 9, 2011 08:43 PM
