AEM EMS Get tuning help for your AEM EMS system.
can a 5 bar map be wired to two different sources?
Old Jul 21, 2010 | 11:51 AM
omniprobe's Avatar
I have a 5 bar map and its currently wired to the ems. I have a tru boost which controls boost. I was wondering if I can wire the 5 bar map to the ems and the tru boost.
Old Aug 12, 2010 | 11:53 PM
SLYDOGRACING's Avatar
I been wondering that for years??????? I wish I knew
Old Aug 16, 2010 | 05:58 PM
BoostWhore's Avatar
I want to say yes but have not tried it.
Old Aug 18, 2010 | 01:19 PM
cuycita's Avatar
+1
Originally Posted by slydogracing
i been wondering that for years??????? I wish i knew
Old Aug 20, 2010 | 07:14 PM
pro-rev's Avatar
The map sensor from the aem has only a 5 volt power source to power the map sensor and the signal it sends back is also voltage based. In theory it will give a reading, but i would not trust it as it is only designed to send an accurate signal to 1 unit. I would buck up and purchase another 5 bar sensor for your true boost. You can however test your theory by doing a pull with the 3 bar map sensor hooked up with your true boost and hit f6 on your comp with the aem for datalogging. Then repeat the pull under the same conditions with the sensors split to compare datalogs. Make sure to press f7 after the runs to end the datalogs. Just compare them to see if the readings differ....
Old Sep 29, 2010 | 06:22 PM
balla48801's Avatar
I have mine like this currently. I have an aem 3.5bar sensor. My secondary unit is not for boost control though just a visual for the zeitronix. I think i would want a standalone map sensor for both, simply because the problem i had below. Boost control and the ems are too critical to play with.
The car would just randomly not start when shut off. I would usually kill the battery trying to get it started. I finally figured out it was because i didnt have the aem supplying the 5v to the map sensor. I had the zeitronix unit supplying 5v to the map sensor and the ems spliced into signal wire. I rewired it were the ems supplied the 5v to the sensor and just spliced the zeitronix unit into the signal wire.
No problems since. I even had to adjust my whole tune due to the change.
karwh0re89
Sep 13, 2012 08:37 PM
evokid511
Oct 29, 2009 07:08 PM
Fairclough
Jun 27, 2009 01:07 AM
raasfaas
16
Feb 13, 2009 04:58 AM
paintballproam
May 8, 2008 06:04 PM
