AEM EMS Get tuning help for your AEM EMS system.
basic settings
Old Nov 18, 2010 | 05:29 PM
leecavturbo's Avatar
basic settings
Any pointers for basic setup.
Crank and cam sensor magnetic with falling edge? Number of teeth and missing etc. Injection phase ?
Got a tuned aem to look at its got some rough running around 2krpm
Old Nov 18, 2010 | 05:35 PM
widge's Avatar
If its only running rough at certain RPM i doubt its going to be anything to do with teeth, cam, crank etc maybe the injector dead times etc
Could just be a real Fat spot in the fuel map, low timing in the area etc,
good luck and post back how you went
Old Nov 18, 2010 | 05:42 PM
I read a few threads about the crank settings giving this very symptoms where rising edge had been selected . It's a small change as far as magnetic hall sensors go.
The tune as far as fuel and timing have been checked for being the cause to this issue by a respected tuner 5 times .
just trying to fine tooth comb it
Old Nov 18, 2010 | 08:58 PM
widge's Avatar
ok cool,
Trigger Angle: 76 degrees
Crank = Falling
Hope this helps
Old Nov 19, 2010 | 02:56 AM
ok cool,
Crank = Falling
Hope this helps
Old Nov 20, 2010 | 07:20 PM
widge's Avatar
How did you go mate?
jtcarstens
Jan 28, 2014 06:51 PM
IX_MR
10
Mar 3, 2013 05:26 AM
Locdizzel
Feb 6, 2012 11:56 AM
PlanoEvo
Jan 26, 2010 03:06 PM
