AEM EMS Get tuning help for your AEM EMS system.
Aem Ems/stock ecu idle problems
Old Jan 24, 2014 | 07:28 PM
jrod740's Avatar
I currently have the FIC 1650 injectors and can't get them to idle or can't get them to work well at cruise speeds. I got the aem ems v1 and can't even get it to start with that. Put old ems back in and have to set scaling to 1084 to get it to drive. Would like to know if there is an easy fix or what injectors would be a good buy that would work better at idle. Thanks
Old Jan 30, 2014 | 05:34 AM
prockish_03evo's Avatar
What type of fuel are you using? On pump gas I'm sure they will be a little tough and will have to run your cars afr close to a 13.0 if on pump. I was on high z id2000 on pump with a stock turbo and was able to do it on pump but while in cruise and idle my afr where way rich but on e85 just my idle was rich so I downgraded to fig high z 1100cc
Old Feb 26, 2014 | 02:41 PM
Enclavet's Avatar
Doesnt matter which injectors you have, you should be able to start and drive around the car depending on how you setup your EMS. Go out with whatever EMS you like the best, drive it and log the data and adjust your maps accordinly.
nutrulz
AEM EMS
Aug 18, 2008 01:49 AM
shunderwunder
AEM EMS
Jun 27, 2008 07:52 PM
smartbomb
Dec 24, 2007 04:49 PM
Evogelion
Northwest Region
Jan 10, 2007 08:45 AM
DXL007
AEM EMS
Dec 18, 2004 08:00 AM
