AEM EMS Get tuning help for your AEM EMS system.
Issue with an AEM EMS V1
Old Aug 14, 2014 | 10:44 AM
cficare68's Avatar
My car has been down for a couple of months now while I was performing upgrades on it. When I got everything hooked back up I put the key in and turned it to on mode. Before the upgrades I would hear the fuel pump engage and the fan kick on. Now I don't hear anything. The fan will eventually turn on but it sounds as if it is pulsating. Plus if I try to link up the AEM it tells me there is no connection. Any suggestions at this point. I have been researching for the greater part of an hour now and have had zero luck,
Old Aug 14, 2014 | 10:50 AM
TheBoz's Avatar
unplug all sensors, and try that. If it is an older V1 the eprom could have displaced from the socket.
Old Aug 14, 2014 | 10:56 AM
cficare68's Avatar
Is there a way I can see if it displaced itself?
Old Aug 17, 2014 | 09:57 AM
cficare68's Avatar
OK so I just got finished disconnecting and reconnecting every sensor in the car. I also pulled the board and checked out the circuit boards. The eprom appeared to be intacted and I didnt see any fired sections on the broad. Car still is having the same issue as it did before. Anymore suggestions at this point?
Old Aug 17, 2014 | 03:09 PM
Aby@MIL.SPEC's Avatar
i would be concerned about not being able to connect to your ecu.
do you know anyone with a aem ecu you can swap out or have them try on their car to sort out the main issue of establishing comms?
Old Aug 17, 2014 | 04:58 PM
cficare68's Avatar
Unfortunately I don't have anyone that I could have test it at the moment. I think my best bet at this point is going to be sending the ecu to aem for inspection.
Old Sep 5, 2014 | 07:10 AM
silentkiller's Avatar
i face this problem on my aem v1. just sent to Aem it will replaced the Emprom chip.. mine the eprom chip is bad.
Old Sep 6, 2014 | 09:08 AM
Jetech38's Avatar
I had the exact same issue a few months ago. The car would die after bumps, and required a battery disconnect to restart, then eventually the pump wasn't priming and it wouldn't start at all or connect to the ECU. I sent it to AEM, paid their $90 fee and got it back a few weeks later. The EPROM chip came loose, causing the no starts/no prime. You might want to jump on sending it in ASAP - AEM recently announced that they're soon ceasing support of v1's due to a lack of parts/age etc... They did give me the option to upgrade to v2 at a reduced price, but IIRC it was almost $1000.
lghtngyello03
10
Jul 22, 2016 03:26 PM
Blue91lx
Mar 4, 2014 05:45 PM
foxbear2277
Aug 16, 2012 05:09 PM
bosshogg34
Oct 28, 2010 10:33 PM
bogey8
Jun 23, 2006 04:52 PM
