AEM EMS Get tuning help for your AEM EMS system.
AEM V1 + Speed Density stalling on start-up
Old Feb 8, 2015 | 02:09 PM
jake33's Avatar
I bought this car last October and basically have kept it in my garage to hibernate through the winter, and everytime when i try to start it when its cold, the engine will crank for about 4 seconds, start-up, and then almost instantly stall out. Is this a common problem for SD? I have to depress the throttle for about 15-20 seconds for it to not stall out throughout that time. 93 tune, dual fuel pumps, 1000cc injectors AMS fuel rail, 2.3 stroker. Any ideas?
Old Feb 9, 2015 | 06:48 AM
maknuge's Avatar
Did it start up fine and stay running fine the day you bought it? Was the battery left on a battery tender during its winter months? Log your starts and idle and see whats going on there.
I used to have a problem where my engine would die right after it started. Mine would die as soon as I let the key return to position II after cranking. I got a new battery and now I keep it on a battery tender and no stalling problems.
Old Feb 11, 2015 | 02:25 PM
jake33's Avatar
The day i bought it, it was warm out and it started ok. Although, after that day when i would try to start it when the engine was cold, it would stall. My idle is at around 1100, very smooth idle. Changed the plugs before I put it away for winter.
I have a PC680 and its a very small battery, I feel like it might not have enough juice. My problem with that is I only have the battery bracket for that small of a battery, Im not sure how i could make a larger battery fit in that bracket. Unless I found an OEM bracket.
Old Feb 11, 2015 | 02:53 PM
Ev0ikon's Avatar
It needs a proper tune. And a good AEM tuner is hard to find nowaday.
Old Feb 11, 2015 | 03:13 PM
jake33's Avatar
It was tuned by Buschur. Although, before I got this car, my friends Evo was tuned by him and had weird throttle problems afterwards, then he went to Motion Lab and gained 15whp over Buschurs tune.
I was thinking of going E85 late this year, and going to Nate at TPG. I know he does good work with AEM.
Old Mar 23, 2015 | 12:59 PM
voodoo-wrx's Avatar
I had the same problem with mine and very frustrating. I spoke to Kevin @ EvoDynamics in Lewisville and he informed me that was a common problem. I was hesitant switching to a stock ECU due to the build. I decided to switch and could not be happier.
Old Mar 24, 2015 | 09:06 AM
jake33's Avatar
It really depends on who tunes it. So far Aby @ Mil.Spec has worked out about 90% of the bugs and the drivability/power are more than before.
HornstarBU
Mar 24, 2015 02:25 PM
okevolutionVIII
Feb 1, 2015 07:58 AM
BoostBuddyGSX
Apr 26, 2012 11:25 AM
Dragking2189
Sep 14, 2011 06:31 AM
06Black
Aug 18, 2011 11:31 AM
