AEM EMS Get tuning help for your AEM EMS system.
fuel tables
Old Apr 25, 2015 | 09:24 PM
MP Evo's Avatar
fuel tables
I'm currently trying to start my car on e85 on 2150 with my aem. Don't want to ignite. Does anyone have any good fuel tables for 2150 with e85?
Old Apr 26, 2015 | 06:32 AM
MP Evo's Avatar
We checked the compression, sparkplugs to see if they're giving a good solid spark, also checked the cam position sensor, belt timing is spot on. Having trouble with the base map to get the car to start. Everything mechanical seems to be good. I got fuel in the cylinders but the car isn't wanting to fire up. It just coughs like here and there it's not like it's catching and spitting and sputtering. Any help would be great or ideas to look.
Old Apr 26, 2015 | 06:54 AM
maknuge's Avatar
Post a screenshot of your start tables. It won't be the fuel map. Don't worry about that until it actually fires up and idles.
Old Apr 26, 2015 | 07:21 AM
MP Evo's Avatar
Ok I'm have my buddy try and email it because it's on his laptop or have him post.
Old Apr 26, 2015 | 05:45 PM
TheBoz's Avatar
https://s3.amazonaws.com/uploads.hip...50cc.V1.19.cal
2150cc e85 SoCal stock block and turbo
Old Apr 27, 2015 | 03:38 AM
MP Evo's Avatar
Thanks. I'll give that a look and compare and hopefully it works. It shouldn't matter on turbo or nothing.
Old Apr 27, 2015 | 09:57 AM
TheBoz's Avatar
well in boost it will matter . Also I live in socal so our cold is only like 50*. So I have never tuned the starts lower than that.
Hope that cal helps.
The start area of the map is a little dirty, because this was a startup cal I was helping someone with a long time ago. I just took my cal, and added fuel in the start range. He was also in colder area. It was the only version I could find.
Old Apr 28, 2015 | 05:01 AM
MP Evo's Avatar
Well last night we tried my buddies aem. Same injectors same turbo all that it starts his car but when we tried it on my nothing Did the same exact thing. On aem you know how there's the crank signal and all that should it bounce between on and off when you try to start the car or stay solid on?
Old Apr 28, 2015 | 11:04 AM
TheBoz's Avatar
stat sync should be on all the time. once the car goes to stat sync on the car should fire.
Old Jan 20, 2016 | 08:48 PM
irvin302's Avatar
Thanks!
razorlab
Jan 5, 2009 06:20 AM
razorlab
Dec 1, 2008 10:00 AM
reyrey
Jan 14, 2008 09:46 PM
