AEM EMS Get tuning help for your AEM EMS system.
Question for anybody who has aem ems!!!!
Old Aug 9, 2016 | 12:24 PM
iLLevo_'s Avatar
Hey guys I recently purchased an Evo IX SE. It has a fully built motor, gsc s2 cams , 1000 cc injectors ,fully built by cbrd with a cbrd bbk full turbo setup. Straight pipe ect. The car runs flawlessly and pulls like all hell. But obviously it burns gas like a ****. Right now it's on a stock ecu flashed and tuned by Chad blocks shop. My question is. If I get an aem ems.. I would then have an option for a multi map setup? Max power on pump gas (93), a low boost Eco mode type of map, and a race gas map.. Is this difficult to do? I'd really like to get a map to just drive to work and not burn all this fuel. I'd appreciate any good input. I'll be checking this thread multiple times a day to see if anyone can give me some clarity on this. Is there any other way to make this happen as well?
Old Aug 12, 2016 | 10:19 AM
TheBoz's Avatar
Yes the aem infinity supports this.
You can have maps fuel and ignition and boost profiles via a trim pot.
You also have full 3D boost maps using ethanol % and trim pot position.
Using that you can adjust your lambda targets and you ignition maps.
So if you want to run a low grade gas map and a high grade gas map you can and you can switch between the two via 0-5v input.
Hope that was the answer you were looking for.
Old Aug 12, 2016 | 10:21 AM
TheBoz's Avatar
I will screenshot some of the tables tonight when I am at my computer.
Old Aug 13, 2016 | 03:05 AM
iLLevo_'s Avatar
Sweet brotha! Look forward to seeing it! Feel free to chime in guys!
Old Aug 15, 2016 | 03:07 AM
iLLevo_'s Avatar
Bump. Still seeking more info!
Old Aug 17, 2016 | 05:56 AM
iLLevo_'s Avatar
Bump!
Old Aug 17, 2016 | 10:52 AM
TheBoz's Avatar
I am not sure why you keep bumping, I sent you a very direct answer to your question. Yes you can do all the stuff you are asking about. You will need a trim pot.
Attached Thumbnails Question for anybody who has aem ems!!!!-boost.jpg   Question for anybody who has aem ems!!!!-ignition.jpg   Question for anybody who has aem ems!!!!-lambda.jpg
Old Aug 26, 2016 | 07:15 AM
iLLevo_'s Avatar
Thx boz
Old May 5, 2017 | 03:35 AM
illusin's Avatar
http://www.aemelectronics.com/?q=pro...ition-trim-pot
Like 40$, running one on my AEM V2 with Kill, 25 lbs and wastegate pressure (14) theboz was right though
Old Sep 14, 2018 | 10:24 PM
CThao21's Avatar
So, I just picked up a IX and it has aem v2. I’m just so clueless of what it is and why you would want the aem v2?
SBR INC
Evo 'For Sale' Electronics / Lighting / Audio
111
Aug 3, 2011 07:48 AM
SBR INC
13
Jun 18, 2010 11:57 AM
SBR INC
Mar 23, 2010 06:26 AM
2JZfan
10
Aug 20, 2009 11:38 AM
ries
Oct 3, 2005 06:10 PM
