AEM EMS Get tuning help for your AEM EMS system.
AEM Basic Unit?
Old Jul 14, 2004 | 09:27 AM
midwestmonster's Avatar
AEM Basic Unit?
If I just wanted to run the basic unit for awhile (stock MAF), could it still be tuned well? Ie. Better than with a S-afc II? I know ideally switching to the speed density will yield better results, but even the basic unit after being properly tuned should give me better numbers??? It's got other features that could be used as well. Any advice would be helpful.
Please don't lecture me on switching to the speed density right away. Money is one issue. Down the road, I will be picking it up. Thanks.
Old Jul 14, 2004 | 10:13 AM
Bump. Anyone?
Old Jul 15, 2004 | 05:11 PM
Blak94GSX's Avatar
Some EVOs have been able to run with the stock MAF, but it is likely to not be much of an improvement over stock. First off, the EMS isn't a power adder directly. It is a tool that should only be used after you have modified the engine to the point that the stock ECU is no longer up to the task.
It is $120 more for speed density.
I don't understand the reasoning of people that think the EMS should be installed right after the intake and exhaust...
Old Jul 21, 2004 | 08:22 AM
TurbotrixRacing's Avatar
why ,,,because its the best hp mod for the car.. You can do an ems on a bone stock car .. with boost controler and make 304whp ...through the stock bov, stock exhaust... Add a full turbo back exhaust and you'll make 340 whp ... You cant touch that ..
Mark
Turbotrix
Old Jul 21, 2004 | 10:49 AM
FOURCED's Avatar
I totally agree with Mark. I'm probably one of the few here who did the AEM as my first mod and from what I've seen you can get a minimum of 50HP from it and up to 90~100 with a boost increase and fuel.
AEM and EVO8 were meant for each other
JDB
Old Jul 21, 2004 | 11:03 AM
Blak94GSX's Avatar
Certainly it is a good unit, I mean I am a huge EMS supporter, but I don't recommend it to people that don't have the experience to be able to tune it themselves.
From an overall cost perspective though, it is best to jump to the EMS as soon as possible since the EMS replaces so many other components that you would normally buy, like boost control, wideband O2, stutterbox, launch control, and a bunch of gauge inputs.
I guess it comes down to how confident the owner is with tuning it, or relying on a tuner shop to take care of it for them. The main problem is that there are a lot of places that claim to be "tuners" but are terrible, and then the owner has a very bad EMS experience. If the owner is close to a good EMS tuner, then that helps a great deal.
Kojimagtrviii
May 31, 2014 02:51 PM
addicted2speed
Aug 4, 2012 11:12 PM
bbyevo8u
14
Aug 28, 2010 04:40 PM
alloutDSM
14
Nov 3, 2008 02:00 PM
blackevolution8
AEM EMS
Apr 19, 2008 04:17 PM
