Lancer 4G93/4G63 Spark Plugs/Leads
Old Jan 12, 2003 | 07:25 PM
SIR GSR's Avatar
Question Lancer 4G93/4G63 Spark Plugs/Leads
Hi guys.
I actually own a GSR (1995), how ever I'm just wondering exactly what Spark Plugs and Leads you guys use for your EVO's?
I just changed my oil and spark plugs on the week end, and now it's making a weird noise. It's like a popping noise, almost as if the spark is jumping off one of the leads and earthing on the heads. But when I drive it, it doesn't miss or anything.
The plugs i put in are NGK Platinums, with a 1.1mb gap. How ever, in the Mitsubishi Owner's Manual it says the gap should be .7-.8mm's. So anyway, I put the old spark plugs back in - no difference, still making the noise.
A friend who used to own a GSR came and had a look at it, he said it was sparking from the leads earthing onto the heads.
Apparently the leads i have to get cost $95AUD - the guy at the shop reckons they're specifically made for my engine.
So, what spark plugs/leads does everyone use? Also, what oil do you guys use in your GSR's/EVO's?
Old Jan 12, 2003 | 10:17 PM
rexhunta's Avatar
i have the whole intake manifold here, with the leads from a 4G63 '94 GSR, that i am selling.. i have a piccie if you wanna know bout it.. has the power thingo and other stuff on it..
i would be willing to negotiate
heres the link ..
https://www.evolutionm.net/forums/sh...&threadid=8506
Old Jan 13, 2003 | 02:03 AM
Alan's Avatar
Try the Bosch Super 4 Spark Plugs. Super Cheap Auto has them for approx. $40 for a 4-pack. Of course by the price, they are the best of the best.
Cheers
Old Jan 14, 2003 | 04:46 AM
GsR's Avatar
GsR
umm is the "popping" like tapping. If you put back your old spark plugs and you can still here the noise it might not be that it could be the valve lifter noise which makes a loud tapping sound supposedly its common in gsr's?
Old Jan 15, 2003 | 12:49 AM
Alan's Avatar
Yeah, I forgot all about the lifter noise. That is more than likely what it is.
Cheers
Old Mar 3, 2003 | 04:28 AM
Raptor's Avatar
Plugs and leads
Hi there
I have the 2002 Lancer Coupe with 1.8L engine Mine still has the standard leads but have changed plugs for NGK Iridium plugs. Haven't noticed as much difference as when I had them in my Camry although I did attain 196 Km/h in a straight line speed test 2 days ago.
I won't use Platinum tho, too expensive and too short lived compared to Iridium. Iridium is more expensive to buy, but lasts years longer!! Iridium is 8x harder than Platinum so this is where the longer life comes from.
Cheers
Old Mar 6, 2003 | 09:18 AM
TurboHead's Avatar
If it doesn't miss while driving then its most probably not the leads... but as a test, lag the extension bits (that go into head) over the full length with insulation tape... make it as thick as you can on the bits closest to the head... and see if the noise is still there.
For the record - I run NGK copper plugs (1 heat range colder) and NGK leads. You can get NGK leaps specifically for the Evo and I called NGK to get the part number and then ordered them through Repco. Were about $50 for the set from memory.
Hope this helps
TH
bjr990
Sep 27, 2017 02:14 PM
kouroshb26
Jan 24, 2016 07:28 PM
mshilto89
Lancer Engine Tech
Sep 30, 2011 09:14 AM
BluEVOIX
Dec 24, 2010 04:29 PM
rEvolution420
Oct 5, 2007 08:31 PM
