Camshaft
Old Sep 22, 2004 | 04:19 AM
Dressedinred's Avatar
Camshaft
Hi guys,
Was lookin for a little advise.
Im am going to supercharge ( one of raptors ) my 4g93 lancer in say about six months. I firstly want to put a cam in it, so i was wondering if the supercharger gring from RPW will run ok on a N/A. Also what extra performance will i gaet with the cam and charger combo over just running the charger. Does any one know Dave from RPW email? I lost it.
Cheers
Old Sep 23, 2004 | 12:06 AM
Sunder's Avatar
1) Cams and Superchargers work very well together, because it allows more air to be forced into the cylinder using less force. This has two effects
A) If you look at the compressor map, the less resisting pressure, the higher the CFM flowed (Higher efficiency - every rotation moves more air)
B) The less resistance, the less parasitic loss on the crank
So you gain both
2) Superchargers are designed for NA cars. It's called twincharging when you put both a super and a turbo charger.
3) Make sure whatever size cams you get, you have absolutely NO OVERLAP. Any overlap at all, will mean your will not hold boost and will get after burn (Unburnt fuel and air in the extractors)
Hope this info helps
Old Sep 24, 2004 | 01:38 AM
Thanks, I will be getting the cam from RPW, seems they have done alot of work on them.
Carrier
Lancer Engine Tech
May 12, 2007 11:34 AM
ralliart329
Dec 24, 2006 06:29 PM
fury656
Lancer Engine Tech
38
May 13, 2003 12:17 PM
Knightliner
Mar 20, 2003 10:22 AM
2wdSQL
Lancer Engine Tech
Apr 10, 2002 09:59 PM
