Automotosports - Illinois Automotosports is a Chicago based tuner specializing in 4G63T performance. With an in-house fabrication facility and engineers on staff, they will be bringing you the best in Lancer Evolution parts.
Ams Alky Kit!!!!
Old Jul 28, 2005 | 10:45 AM
Rollaway's Avatar
send me a kit
Old Jul 28, 2005 | 11:36 AM
BigLEVO's Avatar
eric what is the power in difference that can be had between a 50/50 alcohol/water mix or running straight 100% methanol? thanks
leo
Old Jul 28, 2005 | 11:43 AM
Iceman2011's Avatar
^ what he said. leo check your pm
Old Jul 28, 2005 | 11:44 AM
Sean@Iveytune's Avatar
If I lived in Cali I would have no 2nd thought about doing the meth injection as the gas there is horrible
Sean
Old Jul 28, 2005 | 11:47 AM
I run 100% VP M1 which is cheap and easy to attain, very good quality and remember methanol is hydroscopic so you need to keep it tightly sealed.
Once you run the meth you will never go back , it makes such a difference in what the car feels like powerwise, it moves from a quick car at 350+ hp to a fast car at perhaps nearly 400hp with gobs more torque for finding that open hole in traffic.
Sean
Old Jul 28, 2005 | 11:53 AM
Nesiop's Avatar
You made 353whp before the alchy? You said all the staged upgrades, isn't that their turbo kit then? and 31psi? So you should be looking at around 6--whp.
Old Jul 28, 2005 | 12:02 PM
Rez90's Avatar
Sean, you have me foaming at the mouth for this kit...keep us all updated.
Old Jul 28, 2005 | 12:25 PM
I have all the "stage 4" bolton stuff less the turbo and intake manifold.
Sean
Old Jul 28, 2005 | 12:57 PM
AutoMotoSports's Avatar
The difference in power between windshield washer fluid and straight methanol can be more then 50 whp in the case of an aftermarket turbo. on a stock turbo I can see a difference of as much as 40 whp.
Eric
Old Jul 28, 2005 | 01:15 PM
Nesiop's Avatar
Wait, so how are you running 31psi on the stock turbo? I see by assuming built motor, but I mean the stock turbo can produce power that high and actually allow 31psi?
Old Jul 28, 2005 | 01:34 PM
Jev3gs's Avatar
I thought 31psi on the Stock Turbo was too high anyways. I thought the stock turbo was maxed out at about 25psi, not anywhere near 31 though.
Old Jul 28, 2005 | 02:09 PM
sleet's Avatar
Buschur's stock turbo when he ran 30PSI, the compression wheel blew up and peices of it embedded itself into the housing. He posted pictures in another thread.
Old Jul 28, 2005 | 04:19 PM
warp9's Avatar
I think it can peak there at 30psi, but drops off quickly....
Old Jul 28, 2005 | 10:00 PM
Yes it can make 30psi and that is where the big torque #s come from, remember with the stock turbo whatever you see for torque is directly related to the amount of boost being run.
Sean
Old Jul 28, 2005 | 10:26 PM
johnjonfenomeno's Avatar
can i see pics of this kit
