Ams Alky Kit!!!!
Originally Posted by speede72
690.00 with map sensor ( needed if you dont have a aftermarket enging mangmt system with its own sensor) 610.00 without
Can't you get this stuff at Home Depot?
Also if you get tuned for it...How long does it last? once a fill up? I just dont want to be limited in my use.
ALSO how does say 93 Octane and Alky compair to Pure Race gas?
Ever run a GT3076R on this? THAT would be my selling point right there, making 500WHP on Alky, can it be done at 30PSI?
Theres a thread where a guy with a gt3076 put down 495awhp with alky.
--Josh
--Josh
DO you mean stage 3? Because im checkin AMS website and stage four consists of that tubular header and at GT Garret series turbo etc..etc...could you please let me know if that is stage 3 or 4? or exactly what your setu consist...thanks.
Originally Posted by Sean I
Well I couldn't rest, took the car back made a few small changes and needed to dial it in anyway. Made 401/439 ftlb. Made a few runs over 400hp. Still on the same AMS stage 4, along with Alky injection (No turbo upgrade just the basic BPU stuff). Ran 93 octane pump gas, and VpM1 in the AMS alky injection kit.
I will put the dyno up shortly. I am wondering if I should try the 10.5 hotside just for the hell of it to see if i pickup anything from it. And I think the actuator on this turbo is too loose and is blowing open, dropping boost.
Sean
Sean
Went 11.88@115.1 (3500lb with driver) tonight with the Pumpgas/Alky kit, I think this is it for the stock turbo.
AMS stage 3 has proven excellent in quality and reliability and provides over 400hp to the wheels setup correctly. This is as real world a test as could be and the package proved it's worth on the dyno and at the track.
Sean
Sean
Sean
Sean
