Cobb AP 93 Oct Stage 2 on Stock
Old Feb 15, 2012 | 11:39 AM
yoshe200's Avatar
I've been using stage 2 with everything stock since October (when I got the AP) and it's been running fine. I've experienced much less knocks with stage 2 map than the stage 1 map. I'm not sure what the gain is but I *feel* like the stage 2 pulls much harder than stage 1 or stock. Stage 2 LWG gives me about 22-23 psi when it's cold so I use that in the winter.
Old Feb 17, 2012 | 06:14 AM
emperor496's Avatar
If I am on stock ECU with HKS open pod intake, what stage should I go with?
Old Feb 18, 2012 | 05:38 PM
KechMe's Avatar
Now I'm confused as hell. I have on 08 Evo X MR and was about to order my Cobb AP. Is it safe to use on my stock car? That was going to be the first thing I bought for my car, should I wait until I do an exhaust and go to stage 2??
Old Feb 20, 2012 | 12:59 PM
jthompson8692's Avatar
We are talking about the 2011 evos as the tunes on these are different from the 2008-2010. For a 2008 you should be ok with running stage 2 on stock
Old Feb 21, 2012 | 01:47 PM
thejoshster's Avatar
Can someone post what the timing difference is in the 08 stage 1 vs 11 stage 1? I tried to load 11 in race tuner, but I think it knows Im 08 and it wont load.
Old Mar 3, 2012 | 09:48 AM
bmxking45's Avatar
For any of those who are running the stage 2 map on their stock cars I would like to know if you guys have done the removal of the stock boost pill that is on the solenoid vacuum line. There is actually a video on cobbs website that says for anyone who is running stage 2 maps to do this to their car so that the car can actually achieve the set points the map dictates.
I too am interested in trying the stage 2 maps on my stock car (2010 MR) but I wanted to see I I had to remove the peice prior to reflashing.
Old Mar 3, 2012 | 07:13 PM
Brian303's Avatar
Originally Posted by BakaUnchi
Im going to say this AGAIN
2011 + Stage 1and 2 maps are NOT like the 2008-2010 maps
Stage 1 and 2 work as they are designed and rarely have knock
Every time you post this you are misinforming the public please stop
Understood, but there aren't any Stage 1 AP maps for 2011 GSRs even in your beta directories 17 months after the 2011 GSR was first sold. This being the current reality, do we go with Stage 2 or non-Cobb solutions? Hollywood suggests Stage 2, but I don't think he has a 2011.
Old Mar 25, 2012 | 12:03 PM
arya24's Avatar
im interested in the answer
Old Mar 26, 2012 | 07:35 AM
COBB Tuning's Avatar
We recently released some 2011 and 2012 v200 BETA maps! Have you had a chance to try them out?
-Braden @ COBB
Old Mar 29, 2012 | 09:33 AM
johnnnyjeans's Avatar
2008 stock evo x. just switched from stage 1 to stage 2. LWG. Pill not removed. Boost peak 25psi-25.3psi. Switch it. Pulls harder. No knock. unless I try to jerk the car to produce knock.
Old Mar 29, 2012 | 09:53 AM
I just wish someone from Cobb would address this. If people are getting better results on stage 2 with a stock 08, what is the risk of doing so? Why are people getting less knock(I know timing is less aggressive)?
I dont like running a map that was designed for mods that I dont have. I have very little knock on stage 1. I am tempted to try it, but wish Cobb would either shed some light or give the 08 some map updates.
Old Mar 29, 2012 | 08:11 PM
ethics's Avatar
how safe is stock stage 2 in 2012 mr without removing pill? any experiences?
Old Mar 30, 2012 | 08:51 PM
DEFINITELY feel that higher torque from stage 1 to stage 2.
And. I just pulled the pill. not much difference except it allows me around 0.6-0.8psi more on the boost. AND boost comes SOONER. Around 500rpm.
DO IT. FLASH stage 2 NOW guys.
- 93 oct
- full boost at 4600 rpm (24.4psi-25.5psi) LWG.
- Less knock.
- higher butt dyno torque
- boost sooner and safer
- pill is optional but I pulled it and flashed LWG with Access tuner disabling rear 02 cel.
Old Mar 31, 2012 | 12:51 PM
- 93 oct
- Less knock.
Is it necessary to disable the rear 02 cel?
Old Apr 5, 2012 | 06:55 PM
Texas Tornado's Avatar
I'm running Stage 2 +SF 93oct on my Stock 08 GSR with an ETS intake. Stage 1 ran like crap, Stage 2 feels like it picks up MUCH better. Logged little to no knock compared to the stage 1 map. And yes I removed the boost pill, consistently peaking at 25.2psi. I am getting a pro tune in a couple of weeks when my AMS turbo back exhaust gets put on. I wonder how much quicker a pro tune will make my car compared to the Stage 2 I have on it now.
Hotevo3
Cobb AccessPORT
Mar 31, 2014 01:28 PM
ChipperEvo
Cobb AccessPORT
Dec 2, 2012 07:33 PM
import111
Jul 8, 2011 01:43 PM
SOG RA
Jul 28, 2010 08:24 PM
