K&N Typhoon Intake W/ Cobb AccessPort
Old Aug 19, 2012 | 09:46 PM
skifreakjay's Avatar
So I have a 2010 Evo GSR and purchased the K&N Typhoon intake system and then decided to purchase the Cobb AP. I soon found out that there were no maps for the K&N intake. After a little but of research I found out that because the K&N intake still retains the stock MAF housing you can get by with using the "Cobb SF" intake map. I have had the Cobb Sf intake map while using the K & N intake for 2 days now with no problems and I have been watching the knock... Any input if this is okay to do?
Old Aug 20, 2012 | 09:45 AM
Pbayr0lla321's Avatar
Shouldn't be a problem.
Old Aug 20, 2012 | 03:11 PM
So you think it will be fine?
Old Aug 20, 2012 | 07:41 PM
ihatefwd's Avatar
You should be fine just keep an eye on it
Old Aug 20, 2012 | 11:57 PM
Do you think it will be fine because of the same sized MAF or because the intakes/ intake tube diameters are all pretty much the same?
Old Aug 21, 2012 | 10:22 AM
Kracka's Avatar
Should be fine due to the stock MAF housing. If boost and knock check out then you're good to go
Old Aug 23, 2012 | 08:19 AM
1010's Avatar
+1
I took your recommendation Kracka and picked up the Typhoon for my 2011 GSR. I've had the BETA Stage 2 map on for a week with no problems. I'm getting lower knock counts vs stock. Still getting phantom low rpm low load (so all good)
Thanks again Kracka. Still working my way up to E-85 then FP
Old Aug 25, 2012 | 12:51 AM
So you are running turbo back exhaust as well then? What counts of knock are you getting around like 2500 rpms? Cause sometimes I am getting like 9 counts of knock around 14k-2k rpm.... like 1 of every 15 start from a stops...
Old Aug 25, 2012 | 05:38 AM
MisterHappy's Avatar
Some time shifting and stopping and going will give you "knock". What you really need to watch is what your getting during normal driving/WOT pulls. If you are getting high knock, try using the stock box maps. They worked to me with the ETS.
Old Aug 25, 2012 | 11:08 AM
Yeah, I am getting ZEROOO knock when I am pulling... So it probably is just when i was stopped and shifting again. Im not over boosting and everything checks out! So im guessing the trial is somewhat of a success!
Old Aug 25, 2012 | 11:21 AM
Yea man just keep a eye on the knock, do a test every once in a while, and i would suggest getting a AFR gauge sooner then later.
Old Aug 25, 2012 | 09:25 PM
1010's Avatar
the low load; low RPM knock is usually engine noise (check for vibrations). Use your Cobb AP to monitor your stats and log in to Cobb forums and let Braden take a look at your logs
Old Sep 29, 2012 | 11:25 AM
prune1evox's Avatar
knock with K&N fipk
Hey guys looking for some input, I have a typhoon intake system and am running stage 1 93 cobb sf map. I am getting 1-4 counts of knock past 6500 rpm. I changed the tune to the stage 1 91 cobb sf map and still get 1-2 counts of knock past 6350. Here are the maps, first one is sf 93 oct 4 gear pull to the red line, second one is sf 91 map with 3 gear pull to about the red line. I have read that 1-2 counts are nothing to be worried about....what do you guys think?
Mike Barczynski
Jan 10, 2016 05:06 PM
AsianX610
Nov 4, 2014 10:23 AM
PittEVOX
18
May 24, 2014 02:59 PM
Hotevo3
Cobb AccessPORT
Mar 31, 2014 01:28 PM
trpotts
Cobb AccessPORT
13
Mar 11, 2013 01:50 AM
