Overboost?? Stage 2 AEM 93octane
Old Feb 4, 2013 | 09:24 PM
DGlory's Avatar
I know there's been a few threads about this but I was hoping to post my log and get some opinions. I recently got the parts put on and loaded the stage 2 map, and here's a couple of runs that I logged. I trimmed the fat from the logs but can provide the rest if its important. My parts:
-AEM Intake
-UICP
-Perrin dp + high flow cat
-Buschur v2 quiet exhaust
Without having much background in this, i'm thinking the knock sum of 3 might cause concern and 28.8psi is probably overboosting. Should i try LWG map?
File Type: txt
File Type: txt
Old Feb 5, 2013 | 08:52 PM
DGlory's Avatar
Update:
I switched to the Stage 2_aem_LWG map to try and get the overboost to go away.
Now i'm torn. It was successful in eliminating the overboost - I only hit 26.1PSI max through 3 runs WOT. However, i'm also seeing much more knock with this map. I only hit 3 knock counts once on the old map. Now I have seen as high as 6 knock count! I got consistent 3-5 knocks through 6-7krpm on one pull, and random 6 knock count at very low rpm (1000rpm, casual driving)
Any thoughts?
Old Mar 28, 2013 | 11:37 AM
btack's Avatar
dang 28psi. That's kinda high. map description says 26psi max. Maybe you might want to switch to the LWG map???
Must be fast tho
MivecAddict
Cobb AccessPORT
10
Aug 15, 2012 12:52 AM
Jookies
Cobb AccessPORT
20
Jan 24, 2012 07:20 AM
HELPr
10
May 24, 2011 04:12 AM
adean12
Mar 17, 2011 07:51 AM
