Letting off throttle make engine buck.
Old May 17, 2013 | 12:02 PM
digitalskillz's Avatar
Whenever I'm cruising at a set speed on a straightaway, and let off the gas to slow down a bit, the engine/car bucks/stutters for a sec.
This is with a Cobb stage 2 map and supporting mods. Tuned by my shop a bit after the base map.
My tuner said this used to happen to his X as well with a cobb map, and as soon as he went open source and ditched the AP, he didn't have the problem.
Now of course there's a LOT of variables here, but anyone else running a stage 2 cobb map have this problem?
Old May 18, 2013 | 05:34 AM
Daluv's Avatar
I am on Cobb OTS stage 2 as well and noticed that as well. No suprise since Cobb since to have drop the ball on the evo sadly
Old May 18, 2013 | 11:52 AM
MisterHappy's Avatar
are you running a stock or aftermarket BOV?
Old May 18, 2013 | 11:53 AM
Daluv's Avatar
stock bpv
Mart
Old May 21, 2013 | 09:33 AM
jt8217's Avatar
Mine was having similar issues. It went away after a while. When I refreshed to v400 it started again.
Old May 21, 2013 | 09:45 AM
Stock BOV. Stock wastegate.
Old May 28, 2013 | 08:49 PM
3000GT-GTO's Avatar
The problem your describing used to happen on v201 maps, but with the new v400 map it has improved by a lot.
Old May 29, 2013 | 06:11 AM
sam0329's Avatar
I have that issue when stock, Cobb, and open source
Old Jun 10, 2013 | 03:26 PM
COBB Tuning's Avatar
What modifications are on the car? If you're using the modifications in your signature you're beyond our Stage 2 OTS support and will definitely need a custom tune.
Have you been able to record a datalog of the hesitation occurring? If we can take a look at it we may be able to help diagnose what's going on.
Marshall@COBB
Old Aug 15, 2013 | 08:54 PM
villero1834's Avatar
Same prob here i tou it was related to boost and how the bpv works , lol never tou of it as an actual problemit always happens right after i let go off light boost
Old Aug 15, 2013 | 09:38 PM
sam0329's Avatar
Talk to your tuner if you have one they can help you fix it up a bit.
Old Aug 19, 2013 | 11:36 PM
GeeDubz's Avatar
Even with the same mods as stated with the OTS maps, it may only gets you in the ballpark. Always log and tune to get it dialed in 100% when there are still issues
RA_Dave
Mar 24, 2015 09:42 AM
supwiddiss
Cobb AccessPORT
Jan 20, 2015 07:43 AM
Dmarianodesign
Oct 23, 2014 01:43 PM
evil03
25
May 12, 2011 09:32 AM
