COBB v402 OTS Maps for 2011-2014 Evo X GSR and MR
Anyway, is anyone getting inconsistent boost? I'll hit sometimes 20-21 psi doing a log, while others I'll get up to 22.8. It's weird, tried both 402a and 402a LWG both produce the same results in boost. Both also have the idle issue which I recorded as well.
I think we should at least get a map with support for a cobb intake with no other mods. I mean the whole reason I purchased the combo was being able to run the maps with the intake. Im feeling like I wasted my money almost.
-Eric
In access tuner, open the intake map, copy the MAF scaling table completely, then open the map you intend to use and paste into that map's MAF scaling table. Then save the map and upload it to your AP and flash to the car.
Boom, that's it.
We have updated the original post with V403 maps that address the idle issues some customers were experiencing. If you are on V402a and have an erratic idle, I recommend grabbing the V403 in the original post.
The only difference between V402a and V403 is adjustments made to the idle tables, so the car should perform exactly the same as before but with a more stable idle.
Thank you for the patience while we worked out this issue.
-Eric
-Eric
Just tried out the V403 idle issue looks to be solved good job guys, I must say the Mitsubishi support is finally back and alive this is very fast turn around from 402a to 403.
Just a suggestion maybe you guys can start selling your own intercooler with a new map for the stage 3 people it will probably sell fast too, with just 3port on stage 3 it seem too little for that title.
stock air box with high flow panel filter
stage 3 v403 with stock air box MAF scaling instead of the cobb SF intake scaling that came originally on the stage 3 map
v402a would have the idle get low them bounce around from 600 to 800.
now with v403 it idles bewteen 900 and 1000, its smoother, but a little high for my liking.
