COBB v402 OTS Maps for 2011-2014 Evo X GSR and MR
Subscribe
Jul 24, 2014 | 03:05 PM
  #91
Hmm, hit my first count of 7 knock sum today. Can weather and AC have an impact on knock sum? I wasn't going WOT when I hit 7, but it was over 110* out and I had the AC on. I wasn't datalogging when I hit it, but I did data log a couple other pulls which were 2nd to 4th. No knock or at the very least one count.
I'm running 4.03 with just a catback and newest fuel pump relay.
Reply 0
Jul 25, 2014 | 06:59 AM
  #92
Quote: I am a noob when it comes to cobb accessport, i currently have a 2014 evo x. Recently got an accessport and flashed to stage 1 93 v403, i think that is the latest version. My car is bone stock, i am currently in indiana so its flat, i used both 93 and LWG93, and i am hitting 26psi with knock sum showing around 2-6 after some spirited driving... Just wondering if is this normal or should i be worried.....
Try running the 91 LWG map and you should see the car run a lower peak boost and knock should reduce.
Quote: Hmm, hit my first count of 7 knock sum today. Can weather and AC have an impact on knock sum? I wasn't going WOT when I hit 7, but it was over 110* out and I had the AC on. I wasn't datalogging when I hit it, but I did data log a couple other pulls which were 2nd to 4th. No knock or at the very least one count.
This may not be knock during a pull but false knock/noise, if you can get a log of it post it up. At around 115 the ecu will start pulling timing for high IATs as well. If you are concerned go a to a lower octane map.
-Chris
Reply 0
Aug 4, 2014 | 01:25 PM
  #93
so i currently have a 14 GSR with TBE on, intake will be going on this weekend. i currently flashed the stage 2 v403 map set up for stock intake on my AP v2. the problem i have is that i only have mac and cant download access tuner to adjust the map for the ETS intake.
is there a way to download this map with the adjustments already made or am i kind of screwed?
Reply 0
Aug 5, 2014 | 07:27 AM
  #94
Quote: so i currently have a 14 GSR with TBE on, intake will be going on this weekend. i currently flashed the stage 2 v403 map set up for stock intake on my AP v2. the problem i have is that i only have mac and cant download access tuner to adjust the map for the ETS intake.
Email us at mitsubishi.experts@cobbtuning.com with your intake, year, model, map and octane you want to run and we will send you a map.
-Chris
Reply 0
Aug 5, 2014 | 01:28 PM
  #95
Thanks Chris
Just sent the email
Reply 0
Sep 24, 2015 | 07:35 PM
  #96
Thanks. I've just sent an email. Please help.
I tried to installed almost 34 items (maps) on my AP v3. and still got stuck at 6th gear.No power at all
Reply 0
Subscribe
