COBB v403 Maps for 2008-2010 Evo X GSR and MR
Hi Guys, quick question, I have the Cobb V3 on a JDM 2008 GSR, can I use the 403 maps from the USDM GSR? or will have to stick to the v1.07 World market maps? Either way I get a warning when I try and upload the maps to the AP so I just wanted to be sure
Cheers
Cheers
really digging the new v403 stg1 93 for my stock 08 MR. acceleration feels a lot more urgent at lower rpms and the car feels less sluggish vs the previous 1.08 maps, which felt less sluggish than factory 2008 tune. i drove with factory tune and v403 back to back, and damn, felt like a $1k in bolt-ons upgrade.
gear change/clutch grab is a lot more noticeable now...more a of jerk feeling, even on auto normal. doesn't bother me one bit as i like the aggressive feeling, but this can't be good on the clutches though right? also, top end rpms still falls a bit flat, but i guess i can't expect much more from just a tuned 4 banger.
v403 (and older) OTS Boost Spike in Tune
This is no knock against Cobb. They are and have been awesome. Everyone should use the OTS maps as a starting point and have their car professionally tuned. With that said up front:
I believe that all of the OTS maps from Cobb will exhibit a boost spike when used with launch control. The OTS maps do not use the gear boost selection option like the OEM tune does. As a result the reactive and passive solenoid cycle duties are too high and when launch control is used a massive (28psi+) spike results. I logged this twice at the track and immediately took action to correct. The 1st gear boost targets, reactive solenoid pwm %'s and passive %'s should all be STOCK to save your engine and transmission. Once 2nd gear is in place - wham - then you can use the higher duty cycles on the solenoids. This is an opinion, but something that I measured and corrected. The fact Cobb provides the software to make adjustments for issues like this is friggin awesome.
Has anyone else actually logged boost pressure on LAUNCH with a OTS Cobb tune?
does the v403 maps disable DRLs or am i making this up? DRLs are mandatory here i remember seeing them on before. but they don't turn on anymore. are they just burnt out? i'll have to uninstall AP and see.
-Eric
Been running v403 91 stage3 (ets calibration tables) since it came out and its been rock solid. Some tweaking with boost was required but not a big deal.
My LTFT's have been spot on too. Under 2%.
