COBB v403 Maps for 2008-2010 Evo X GSR and MR
Hey guys! As you've seen in our other thread, we've been updating the calibration files for the Evo X. We have carried the improvements learned with the 2011-2014 cars into these maps in hopes of offering a complete host of maps for all USDM Evo Xs.
Thorough testing has been done in-house on multiple vehicles however before pushing these maps to full release we would like to hear your feedback. Please feel free to submit datalogs and ask any questions you have. We’ll do our best to answer your questions and make any changes to the calibrations that are deemed necessary.
Make sure your Accessport firmware is up to date using Accessport Manager,and the maps should then be on your device. You can also download the OTS maps off of the maps section of the COBB Tuning website.
NOTE: V403 Maps have been moved to full release and can be downloaded off of the COBB Tuning website.
As always, thank you for your continued support!
COBB Mitsubishi Team
Nice! Have any major changes been made with these and the v402 maps that I helped to send logs on a couple weeks back? My car is running pretty nicely with the v402 Stage 2 map. Have not had the chance to do the Stage 3 yet though. I will use this map and send you the logs when I am able to.
I just received my V3 Accessport two days ago. Downloaded the AMS Stage 2 93 Octane map and reflashed. No issues. How can I help with the datalogs and when should I datalog? This is my daily so when should I start to log to help you guys?
What stage map are you running and what modifications do you have on the car?
Just putting in my experiences on v403 here like others.
I'm running the stage 1 ACN LWG map. My idles don't bump around anymore in the 600k RPM range anymore, but it seems rather high in the 1k RPM range at idle.
Although because the RPM's idle higher now, my MR seems faster since it doesn't have that little lag at the beginning when putting some throttle on which is great.
So far the V403 has been awesome, only thing I've noticed on a stock stage 1 tune is that the idle hangs up a little bit when you let off the gas before going back down say between downshifts or when coming to a stop at light going from 2nd to N but it's pretty inconsistent as to when exactly it happens and not a tremendous issue.
I will share my findings/results
