Which map should I use?
Old Aug 27, 2014 | 04:01 PM
bgemk911's Avatar
I have a 14 evoX gsr with stock dp, ets test pipe, stock cat-back(for now), ets intake, and manual boost controller. Which map should I be using? Thanks.
Old Aug 27, 2014 | 04:05 PM
e_kobz's Avatar
You should go get a real tune. While the OTS maps are good, they're not great. Go get a tune specific to YOUR car.
Old Aug 27, 2014 | 04:33 PM
bgemk911's Avatar
Eventually i'll get a "real" tune, but which is the best OTS map from Cobb for my mods?
Old Aug 27, 2014 | 05:27 PM
e_kobz's Avatar
I would contact Cobb and get their opinion. If you're adjusting boost with the mbc then getting a real tune is your safest bet.
Old Aug 28, 2014 | 09:02 AM
COBB Tuning's Avatar
Hey Man,
As it turns out we do not recommend you use a manual boost controller with our maps. Given your mods I would recommend you either upgrade your car with a full turbo back exhaust, run the stock ECBS and run our stage 2 map calibrated for your intake. Or, you can have a pro-tuner create a custom map for you. Here is a link to our dealers and tuners. You can use the link to find a pro-tuner that is located near by.
http://www.cobbtuning.com/Dealer-Ret...or-s/70471.htm
-JOHN
Old Sep 26, 2014 | 08:06 AM
bgemk911's Avatar
ok, as of now i have ets intake, ets test pipe, and ets extreme cat back. Should i still go with with the stage 2 map?
Old Oct 2, 2014 | 03:52 PM
.M.'s Avatar
.M.
^Yes. But don't forget what cobb stated about the boost controller.
Old Oct 3, 2014 | 05:01 AM
bgemk911's Avatar
Yea, I'm not going to go with the mbc. I'm still running the stock downpipe. I am good to go to stage 2?
Old Oct 3, 2014 | 07:16 AM
Stage 2 should be fine as long as you do not do multiple consectutive pulls, without a full turboback you can buildup heat in the exhaust system that can cause knock.
-Chris
Old Oct 15, 2014 | 07:14 AM
bgemk911's Avatar
I am running stage 2 with ams dp, ets intake, test pipe and cat back. Do i really need the ECBS to run stage 3? Thanks
Old Oct 16, 2014 | 07:17 AM
Yes. Stage 3 is not compatible with stock solenoids, you remove both factory solenoids and replace it with one that can actually control boost efficiently.
-Chris
Old Oct 16, 2014 | 11:16 AM
bgemk911's Avatar
Thank you.
Old Nov 16, 2014 | 07:54 PM
Junior_evox's Avatar
-Chris
Ive been reading and i also have test pipe and a straight piped exhaust but still on stock dp and intake. Can i move up to stage 2?
Keedo
Cobb AccessPORT
Oct 20, 2014 07:47 AM
twinkiemobile
Cobb AccessPORT
30
Sep 2, 2012 02:46 AM
SeanM505
Cobb AccessPORT
Aug 24, 2012 09:52 AM
bmxking45
16
Aug 1, 2012 02:32 PM
