View Poll Results: what vendor would you choose to do turbo upgrade and tune
AMS
22.92%
Buschur
22.92%
Vishnu
22.92%
Works
3.13%
Turbo Trix
18.75%
Other
9.38%
Voters: 96. You may not vote on this poll
went to the track and have ?'s
Old Nov 22, 2004 | 01:14 PM
  #31
stringer's Avatar
youd have to call them to be sure ask for arron he'll let you know not tp be a dick but you think it might be a little driver error you went with me to get that fuel pump you know im a non shifting *****
Old Nov 22, 2004 | 01:21 PM
  #32
TampaTurbo's Avatar
Hey whats up man? Do you need the stocker pump back? I have it if you need it. I wouldnt say its driver error. I had 1.7-1.8 60fts which I think arent bad and flat foot shifted at redline with no problems. It feels like there is power but doesnt appear to be with these times.
Old Nov 22, 2004 | 02:21 PM
  #33
TampaTurbo's Avatar
So far I am torn between TurboTrix and AMS. Both very top notch. I am not sure about the comparison between the build/quality of parts to make a final decision yet but I am thinking I am going to go gray over this. Both are confident I can achieve 430WHP with either of their kits which is making this very hard. AMS's turbo kit is on the higher side but thats why I need to find out the differences on build/quality. I guess the turbo to compare with would be AMS 3071R to TT comparable turbo. Both will make the same numbers. ahhhhh. If anyone is knowledgeable between both kits, please chime in.
Old Nov 22, 2004 | 03:34 PM
  #34
masterevo's Avatar
how is ur idle with the 272s? I dont like mine one bit....
Old Nov 22, 2004 | 04:11 PM
  #35
05-EVO-GSR's Avatar
yeah
Old Nov 22, 2004 | 04:26 PM
  #36
TampaTurbo's Avatar
Originally Posted by 05-EVO-GSR
yeah
I dont mind. They have been tuned out at one point with the UTEC by advancing the timing in the low rpm range and adding some fuel. It was nice. Then the fuel pump went bad during the tune and messed everything up and I started stalling around every corner. I had to set it back to stock timing to keep it from stalling so I have the lope again. I'll get it tuned out again since I have the new fuel pump.
Old Nov 24, 2004 | 04:02 PM
  #37
mlody77's Avatar
u got nice stuf in your car ,u must run low 12',did u got your computer flush ?whot is your wwhp?
Old Nov 24, 2004 | 04:10 PM
  #38
mlody77's Avatar
got invidia 3" full exhaust .manual boost control,intake ,change clutch cable and take the plate out ,stock clutch !!!!21 boost i ran 12.8 at 106 mph my 60 time 1.80 .turbotix good stuf give them a call 732-572-6566
Old Nov 24, 2004 | 04:14 PM
  #39
plokivos's Avatar
maybe its the stock clutch
Old Nov 28, 2004 | 06:42 PM
  #40
TampaTurbo's Avatar
unfortunately it doesnt feel like the clutch.
Old Nov 28, 2004 | 08:47 PM
  #41
Jakeg97's Avatar
try a different track
Old Nov 28, 2004 | 08:55 PM
  #42
jj_008's Avatar
You can't go wrong w/ AMS or TT. I definitely think your tune is not optimal. I have a Vishnu stage1+ w/ 272's and the only time I have been to a drag strip, I went a crappy 13.4@108 w/ a 2.1 60' and hitting the rev limiter twice. You definitely need to get your car looked at.
Old Nov 28, 2004 | 09:05 PM
  #43
bbbwrx's Avatar
Any good tuner should be able to tune your UTEC. If they can't figure a Map load point vs TPS tuning then I wouldn't trust them with my car. They might not have worked with it a ton. But they should be able to tune your car.
Ben
Old Nov 29, 2004 | 01:26 AM
  #44
Frank Dux's Avatar
I like the AMS guys. I Have been there a few times and talked to a few of the guys and they seem very knowledgable. I have also driven one of the cars that they tuned with basic bolt ons and was very impressed. Alot of people around Chicago really like them along with me. I will tell you this though, I saw their o2 housing for the turbo kit and it looks mint. It looks like they spent alot of time on that piece, so I take that as an example for the rest of the turbo kit and it gives me a good feel for it.
Old Nov 29, 2004 | 07:04 AM
  #45
TampaTurbo's Avatar
Thanks for some info. Trying a different drag strip wont make me feel better because of what my M3 buddy ran. Anyway, Even if i was a crappy as hell driver, I should still have higher traps. rrrrrrrrrrrr There is central florida turbo in Orlando that said they can tune the **** out of the UTEC. I will give them a call and see what I can find out. I do need to get this resolved before I compound problems with adding a turbo kit etc.
