Best size drag radial?
Old May 1, 2005 | 10:41 AM
dr.mr's Avatar
What is the best size drag radial tire (and brand) to help induce
tire spin during a launch and thus preserve the drivetrain?
I am at 364 awhp and will use the stock 17x8 rims.
Old May 1, 2005 | 02:01 PM
dr.mr's Avatar
Maybe 205/45-17 or 215/45-17 ???
Old May 1, 2005 | 05:00 PM
DSMotorsport's Avatar
So you want a sticky drag race tire, but one of your issues is making tire spin?
I would suggest the BFG 245 45 17 drag radial. Don't expect much tire spin though at 375whp level.
Old May 1, 2005 | 06:18 PM
dr.mr's Avatar
The 245/45-17 is a little wider than my stock tires now!
I was thinking about going skinnier than stock to get more tire spin,
just at the launch!
Old May 1, 2005 | 06:36 PM
just at the launch!
so what is the problem with stock tires then. you don't want tire spin, that's completely backwards. If you want to go fast and get better ET, you need traction and not tire spin.
if you want tire spin, stop looking for drag tires and just get cheap kumho's.
This is like asking what exhasut makes the most power, but wanting a 1" diameter low flow cat to keep it quiet.
the only time you will ever spin the tires is at the launch, and that is when you DONT WANT TIRE SPIN.
Old May 1, 2005 | 07:12 PM
11secEVO7's Avatar
honestly....
You can get tire spin if you just launch the car hard...
I launch at 6K...get 60ft times of about 1.8xx on sumitomo 235/40/18's...
this is alot of wheelspin..which I really dont want. Goin to try the hoosier drag radials next!
Old May 2, 2005 | 08:34 AM
dr.mr's Avatar
I think your missing my point. Evo's were not made for drag racing.
So I DO want tire spin ESPECIALLY at the Launch.
Without tire spin you're putting to much pressure on your drivtrain!
I'm not talking about burn-out contest tire spin, just enough to take
some pressure off the drivetrain and get a good 60' time.
So if anyone out there has tried running skinnier tires for drag racing
let me know what you used and how were the results.
Old May 2, 2005 | 12:25 PM
11secEVO7's Avatar
what we're saying is...with that power...and on 17's....
a 5000rpm launch would give u the tire spin u want.
Old May 2, 2005 | 12:44 PM
dr.mr's Avatar
OK, I'll just leave my stockers on and try a higher rpm launch, maybe with
my new twin-disc clutch I'll improve my 1.98 60' time.
Old May 2, 2005 | 06:15 PM
11secEVO7's Avatar
yeah...I had an HKS twin disc on..
car was basically stock...with the addition of nitrous and boost control..
the twin discs can take high rpm launches..so u are safe..
just slip it coming off the line.
I got consistent 1.8 60ft times...and this is on a crappy launch pad with sumitomo tires.
Old May 2, 2005 | 07:32 PM
you never gain anything with tire spin. These drivetrains are extremely strong, spinning the tires does nothing but waste energy that could be pushing your car to faster 60'. Then when the tires cartch traction, you put more shock on the drivetrain than if you just launched with the correct amount of traction and clutch slip.
Trust me, I know as much as anyone about launcing awd mitsubishi's. My best 60' time last friday night (1.575) is better than ANY usa evo8 on http://www.dsmtimes.org/evo.htm
my talon also does consistent 1.50 to 1.54 short times.
I think if you want to get better 60' times, go ahead and buy a set of drag radial tires and slipthe clutch enough.
if you don't care about drag racing (since evo's are not made for dragracing, or so everyone says), just use the tires you have.
I just don't get why you want to buy tires specificly to spin at the dragstrip thinking this will somehow help your 60' or save your drivetrain. That's false on both issues.
I think evo's are awsome drag cars for street tires. If not the BEST drag car availble.
Old May 3, 2005 | 04:31 AM
94AWDcoupe's Avatar
Actually its now well known fact that tires transfer max power with 10% tire spin. Another phrase for it is "hazing the tires" You will get max acceration from the launch when you haze the tires.
Old May 14, 2005 | 05:52 PM
rACerS's Avatar
that is a great 60' what tires are you running?
Old May 16, 2005 | 08:31 PM
Kumho ASX all season tires 235 45 17. They are worn flat now, Im probobly going to get another set of cheapo's for everyday use, and find a second set of evo wheels to put a set of drag radials on for track use.
3gEclipseTurbo
Jan 2, 2011 05:22 AM
dambikeracer
Apr 7, 2009 04:29 PM
TOMMY B
Jan 29, 2009 07:33 AM
importdps
Evo 'For Sale' Wheels / Tires
16
Aug 29, 2008 12:47 PM
Smogrunner
Dec 12, 2007 12:04 PM
