went to the track ....
Old Jul 30, 2005 | 08:57 AM
evodave's Avatar
From: driving the 10 second beast in ohio or running lightmods.net
i need to adjust the clutch rod out...i have been trying to slip it a few times with NO luck ...i think the biggest problem is not the fact that the clutch is too grippy or can't be slipped but i think that its cause of the fact that it fully ingages at the bottom /floor
Old Jul 30, 2005 | 10:39 AM
regularjackass's Avatar
good run slick
Old Jul 30, 2005 | 11:16 AM
Jasil's Avatar
Yep, I would agree with that, TRE even said the clutch should engage about 3'' from the floor.
Old Aug 5, 2005 | 11:54 AM
evodave's Avatar
going to adjust it today and road test it!
Old Aug 5, 2005 | 12:18 PM
evoviiiyou's Avatar
Nice Dave, Have tym extend your rpms a few hundred rpms or so that going thru the traps at the top of 4th. And turn up the boost to 30-32 psi. for pete sakes....J/k Nice run but you definatley have a 10 in there for sure.
Old Aug 5, 2005 | 12:20 PM
evodave's Avatar
i loaded the software into our laptop so i can do it...i am going to also up the air pressure in the tires to help aid in some wheel slip, adjust clutch and some other minor stuff....i will make some passes at higher redline at the same 27 psi....then go from there.
Old Aug 5, 2005 | 12:23 PM
evoviiiyou's Avatar
Well shiz, just program a 2 step at 5500-5800 rpms to make the launch easy to repeat. If you get wheel hop it is to high, if it bogs not enough etc... good luck man...that is one nice set up you have.
Old Aug 9, 2005 | 08:31 PM
evodave's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=153046
Liqquid
Jun 27, 2015 01:00 PM
740 Turbo Brick
Jun 12, 2015 03:07 PM
evodave
126
Mar 14, 2006 10:03 AM
evodave
Aug 18, 2005 08:23 AM
TrinaBabe
Jul 28, 2005 05:32 AM
