So close yet so far away!!! 11.1 at 129 then bye bye front diff again!
Old Sep 6, 2005 | 08:29 PM
evodave's Avatar
From: driving the 10 second beast in ohio or running lightmods.net
Well guys.... as you may or may not know i have been fighting to hit 10s on pump gas with stock motor (besides cams and headbolts) , stock ignition, stock intake manifold and throttle body and stock front diff (killed the second one now) and tranny. Here is a link to the motor setup ( i feel with almost 130mph traps that the car is making more then it did on the dyno....
https://www.evolutionm.net/forums/sh...d.php?t=149659
Well here are the races we did in order of links (oldest to newest)
11.3 at 126.4 https://www.evolutionm.net/forums/sh...d.php?t=153046
11.3@125 11.5@127 https://www.evolutionm.net/forums/sh...d.php?t=153903
11.2 at 128.3 https://www.evolutionm.net/forums/sh...=155354&page=3
on this run i broke my stock front diff and towed it home not knowing originally what was wrong....
well tonight i ran 2 runs and broke the stock diff again (either going ralliart from TRE or quaiffe (however you spell it) i ran:
11.2 at 128.5
then my buddy brian ran:
11.1 at 129mph but then came back around and tried to run again and the diff gave up the ghost (hopefully thats all it was ) i drove it home (limped ) and i am going to get it apart up at slickmotorsports soon and do something with the diff asap so i can just stop worring about destroying these
Old Sep 6, 2005 | 08:36 PM
2SloEvo's Avatar
Dave, your makin great power and you will meet your goal once the correct parts are on the car, just keep pushin! Trap speed is insane on stock block and valve train!!!!!!
Old Sep 6, 2005 | 08:37 PM
TwStDeVo's Avatar
a quaife is definitely in need!! nice results though, i have been hoping you hit 10s since you started the original thread, looks like with the quaife, you can get better traction and hopefully dip into the 10s. your car is definitely a pump gas monster!!
matt55's Avatar
Dang again , TRE !
Old Sep 6, 2005 | 08:42 PM
evodave's Avatar
i need the lsd ...i am a diff eating machine! I want the RS limited slip for sure... but i would do with the ralliart one or the quaife . SOMEONE HELP ME HERE!
Old Sep 6, 2005 | 09:04 PM
smp3000's Avatar
Dave the quaiffe is the best product out there.
Old Sep 6, 2005 | 09:09 PM
WHTEVO's Avatar
i would also recommend the quaife. lifetime warranty whether racing or not as i understand it. good job on the times. good luck.
Old Sep 6, 2005 | 09:45 PM
evodave's Avatar
thanks guys!! i need a quaife i guess! i have heard the RS diffs are like unbreakable also
Old Sep 7, 2005 | 04:30 AM
rsr14's Avatar
I have an RS lsd for sale for much less than a quaife. Send me a PM or e-mial if you are interested.
coryf@knology.net
Old Sep 7, 2005 | 04:42 AM
DCSilvrEvo's Avatar
i have the JDM Evo 7 front diff, same as RS. Mt car launches like a bat outta hell!
Old Sep 7, 2005 | 07:10 AM
Jasil's Avatar
For all the Quaiffe bandwagon jumpers just remember if you ever track the car and lift a wheel the Quaiffe will become just like a open diff. That's why KAAZ or clutch type diffs are much more popular in road racing. Shep uses a KAAZ and so does Magnus.
If your sure your only going to drag the Quaiffe is fine.
Old Sep 7, 2005 | 07:40 AM
evodave's Avatar
coryf@knology.net
emailed ya
Old Sep 7, 2005 | 07:44 AM
mike 99gsx's Avatar
Dave,
Did you ever look at the 2 step retard rev setting that I was talking about in your other thread?
Old Sep 7, 2005 | 08:32 AM
4G63>OOOO's Avatar
When have you ever seen a road racing car lift a front wheel? I think you have bigger things to worry about at that point.
In all seriousness, though, considering the plug and play of a Torsen diff and the constant fiddling you're always doing with a clutch type diff (swapping discs, changing fluid, etc), for anything short of a full race car with a big budget, the Quaife is the way to go, IMO
Old Sep 7, 2005 | 08:49 AM
evodave's Avatar
so if i put in a RS lsd i will have to mess with it? I was under the impression that it was bolt in
