How are you launching?
Old Apr 12, 2006 | 12:25 PM
EvolEvo's Avatar
Question How are you launching?
I have a evo VIII and i'm hitting the 1/8th mile track around here in about 6 weeks. i have drag launched my car before slipping it till a point then droping it(note: i have a ACT clutch). worked out very well so far havent broke all four tires loose like that but i've had real good take offs against v8 stangs with toyo ra-1's(?). But my question is how is everyone launching? because the way i'm launching i think contributed to my broken front diff..
Old Apr 12, 2006 | 12:28 PM
KOEvo's Avatar
search
Old Apr 12, 2006 | 12:30 PM
diablors's Avatar
Have you tried to feathering out the clutch??? That was the way Al from Dynoflash showed me how to launch my evo.
Old Apr 12, 2006 | 12:36 PM
EvolEvo's Avatar
Sorry, but dont quite understand what feathering out the clutch means...i had a type-r before so i really just had to drop it.
Old Apr 12, 2006 | 12:37 PM
SterlingEvo's Avatar
If you are serious about launching/dragging, then send your ECU to Al or somebody to add the 2-step... that takes 1/2 of the thinking out of it, you don't have to worry where your RPMs are...
Old Apr 12, 2006 | 12:43 PM
EvolEvo's Avatar
even though i'm running a utec...i think they are "supposedly" coming out with one with their next update of the software.
Old Apr 12, 2006 | 05:55 PM
fellowx's Avatar
Launch at 5.5K-6K.. Once you get the revs up there beyond 5.25K you're pretty much good to launch.. You can almost dump it.. slight slip..
Old Apr 12, 2006 | 06:04 PM
SpyderBite's Avatar
exactly what he said.
I revv. mine up anywhere from 5-6. And do what I call a fast feathering. Just let it out at a moderately quick pace while adding throttle then release.
Old Apr 12, 2006 | 08:31 PM
Warrtalon's Avatar
If you don't have launch control, then like this:
12.26 on 93oct
Warrtalon's 12.000
If you DO have launch control, then like this:
6k 2-step
Old Apr 19, 2006 | 07:47 AM
DrivenToThrill's Avatar
12.26 on 93oct
Warrtalon's 12.000
6k 2-step
So if you have that launch control you can just floor it with the clutch in and the engine won't blow up? What could happen and what couldn't happen from doing this? Im sure theres down falls to it and Im sure theres good things too. Could someone tell me?
Dante`
Old Apr 19, 2006 | 07:57 AM
smoothmarine187's Avatar
Veteran: Marine Corp
I haven't found any downfalls with the 2 step. I pulled a 1.61 60' and that was on all season tires! You just floor it.......slip the clutch quickly and your off. I hardly got any burnt clutch smell, compared to when I launched without the 2 step.
Old Apr 19, 2006 | 08:03 AM
tke_413's Avatar
Probably a stupid question BUT.....I have a TurboTrix flash, is there any way to leave everything the way it is but have the 2-step added?
Old Apr 19, 2006 | 08:28 AM
I'm sure that Al could add the 2 step for you without changing anything else.
sleet's Avatar
Yes.
PalmTreeZ
May 21, 2017 12:43 PM
bboy_RES
Mar 30, 2008 08:40 PM
tlcoll1
53
Apr 15, 2006 06:56 PM
IS2000
Dec 4, 2003 12:32 AM
