Disappointing times tonight
Old Sep 5, 2006 | 03:49 PM
  #31
Kerr's Avatar
Fomer Vendor
Originally Posted by 34Turbo
Best time I ran was 12.4 with 344awhp with 80-90F temperatures and high humidity. I'm shooting for 12.0-12.2 this Friday since it should be in the 60s, 70s.
With 24psi on a 8 you may be pulling timing. I would suggest putting in some race gas next time and leave everything the same to see if thats the case.
See, and thats what I was expecting, maybe a little better. I don't know about the timing, I know I keep saying it, but if I had a laptop I would have loged it and checked.
Good luck hitting you goal too.
Old Sep 5, 2006 | 03:51 PM
  #32
Kerr's Avatar
Fomer Vendor
Originally Posted by AlwaysinBoost
if your tuned right 24psi is no problem on pump gas. that is what I run. best time to date is 12.4at110 on an VIII
I think the tune is right, Jestr has been doing this a long time and I don't think he would do something that wasn't safe.
Old Sep 5, 2006 | 03:55 PM
  #33
Kerr's Avatar
Fomer Vendor
Just so you know 24psi on the street doesn't always equal 24psi at the track. I also have a 3bar MAP sensor so I know exactly how much boost I'm running. I need to turn my MBC up about 1/2 a turn from how I drive on the street otherwise I'll only be @ 20psi while blasting down the track. It has to do with how the car is loaded when doing a 3rd gear pull from 2k-7k rpm on the street vs. shifting 1st-4th @ 5-7k RPM.
I understand that, but all I can tell you is from what John said. Im not basing my boost read out on my guage because I know its off. But I am also running the GM boost controller through the EMS.
Old Sep 5, 2006 | 03:56 PM
  #34
AlwaysinBoost's Avatar
i wasn't saying there was anything wrong with your tune. I just said I run 24psi on pump gas and have no problems. I'm sure if your tuner set your car up properly there is no problems.
My friend has a custom tune from TT on his car. On 91 octain with 100% humidity and well over 95* heat he trapped 109 MPH at 24psi with pumpgas... its all in the tune.
Old Sep 5, 2006 | 04:00 PM
  #35
then you need to get a laptop and log your boost. you can't trust what your boost gauge is telling you, espically during a drag pass when your paying attention to some many other things. I willing to bet your not hitting that same peak 24psi at the track that you do on the street.
Old Sep 5, 2006 | 04:02 PM
  #36
Kerr's Avatar
Fomer Vendor
I know you weren't, I didn't mean for it to come off as defensive. Just talking.
Old Sep 5, 2006 | 04:04 PM
  #37
Kerr's Avatar
Fomer Vendor
I would have had a laptop, but it was a friends parents that I was going to borrow. They didn't feel "comfortable" letting me take it to the track.
Old Sep 5, 2006 | 11:53 PM
  #38
SKILMATIC's Avatar
Correct, its the HD. And this whole statement is what I was thinking. And I think your starting to figure out where I'm coming from.
I know my clutch isn't making my car slow. And I understand what everyone is saying about the 24lbs, Im going to talk to John, but I completely trust him.
I just hope that when I get the launch down, and the traction better, that my et will be what I had expected.
No problem. Just hope you get everythign figured out. Good luck to you.
Kerr
Nov 5, 2008 07:28 AM
Kerr
Mar 11, 2007 07:50 PM
Kerr
Southeast Region
Aug 26, 2006 08:06 AM
Kerr
May 5, 2006 09:34 AM
Kerr
Apr 28, 2006 07:53 PM
