trap speed question
Old Sep 20, 2006 | 07:17 AM
AlwaysinBoost's Avatar
trap speed question
I'm curious what the below average, average, and above average trap speed is for a basic bolt on EVO8 or 9 with stock turbo on pump gas. By basic bolt-ons I mean everything including cams but not including alky, just looking for straight pump gas numbers here, no race gas.
Please list as many power mods as possible, weight reduction done if any, and your 1/8th & 1/4 MPH. Dyno numbers are ok to list but just as a reference in comparison to your trap speed. I'll start off...
Car weight: 3500 w/driver
Weight reduction: spare tire, front rebar removed,
Power Mods: 10.5^cm hotside, ebay o2, 3" tbe w/test pipe, mbc spiking to 23-24psi dropping down to 20.5 @ redline, cone filter, ebay IC, JDM MR BOV, self tuned.
Dyno: 320whp/316wtq @ 23psi
Traps @ above boost level
1/8th: 85-86mph
1/4: 110
Old Sep 20, 2006 | 07:58 AM
EVIL_EVO_VIII's Avatar
IXs average traps on pump with boltons are 110-112mph.. I trapped 110 in the 1/4 and 89.58 in the 1/8 on pump with catless tbe, mbc 21 psi, o2 housing, megan manifold, and reflash.Everything else is stock!
Old Sep 20, 2006 | 08:28 AM
thats a NICE 1/8th mile trap.
I see your sig says @ 22psi you trapped 110.01 but you list 21psi in your post.
Also was that a one time thing, the fact that you trapped 110.01 or is that more of an average?
Old Sep 20, 2006 | 08:31 AM
it was around 21-22 psi.. Well i dont know what the average is for my mods but ppl tell me i have a strong car, maybe Clay can answer this question for you.. I kept up with a super charged s2k that trapped 112 in the 1/4 from 2nd gear and 3rd gear roll..Funny thing is that when i posted my times the 1st time for these runs, ppl thought i had a IX
Old Sep 20, 2006 | 08:47 AM
sorry I wasn't more clear... by average I just meant was that 110.01 trap just a one time thing or do you usually trap 110.
Old Sep 20, 2006 | 08:54 AM
Boltz.'s Avatar
FCOTM Winner
18k on it. I ran it with full interior, over a 1/2 tank of gas (100% 93oct.), the spare/jack/tools, the car is mechanically stock minus the following mods;
3" TBE
Forge UNOS MBC @ 21.5psi>18.5psi taper
AMS LICP
FORGE BOV
It was about 70 degrees out, 50-60% humidity. I only got to make 3 runs and since I'm on the stock clutch I started easy in the first 2 runs to get a feel for it (I dont launch it often). I gave it hell on the third pass and was satisfied for the night so I left, with no broken parts
The car made 265whp in this tune.
Anyways;
60'-1.786
330'-5.199
1/8-8.072
MPH-85.71
1000-10.582
1/4-12.710
MPH-106.18
Old Sep 20, 2006 | 08:58 AM
The day that i trapped 110. i ran 12.5 5x in a row at 109 and in the last pass i trapped 110 so it was pretty consistant.. Before i was tuned with the same mods, i was trapping around 85 in the 1/8th and 106.87 in the 1/4..It was about 72-75 degrees out
Old Sep 20, 2006 | 09:15 AM
3" TBE
AMS LICP
FORGE BOV
Anyways;
60'-1.786
330'-5.199
1/8-8.072
MPH-85.71
1000-10.582
1/4-12.710
MPH-106.18
was this an 03, 05, or 06 EVO? and was the car tuned at all?
Old Sep 20, 2006 | 09:17 AM
damn 5- 12.5's in a row, very consistant and so close to 12.4; just a touch more boost & a little cooler weather and your there.
Old Sep 20, 2006 | 09:42 AM
Tell me about it!! I was doing what i could to hit 12.4 but couldnt.. Going back to the track when it gets cold again.. My goal is 11.99 on pump with current mods and clutch/flywheel, licp....We'll see see what happens
Old Sep 20, 2006 | 10:14 AM
C6C6CH3vo's Avatar
04 SSL (stock weight - whatever it is - it's the heaviest)
10.5, cams, custom dynoflash, 93 oct, boost spike to 23psi, stock catback
1/8
88.7 mph
8.0 ET
Shifted to 4th, 245/45/17 tires
I would estimate WHP at this time on mustang would be like 260
Old Sep 20, 2006 | 10:26 AM
dayf's Avatar
deleted.. nevermind.
Old Sep 20, 2006 | 12:22 PM
1/8
88.7 mph
8.0 ET
thats a great MPH for stock cat-back. Are you running a stock DP or is that aftermarket?
Old Sep 20, 2006 | 12:35 PM
Smike's Avatar
https://www.evolutionm.net/registry/times.php
Race weight - about 3250 lbs
Old Sep 20, 2006 | 12:38 PM
C6C6CH3vo's Avatar
To ease your mind, catback was overhauld a little:
3"DP, cat delete, stock catback (tapered flange where 2.6" mates to 3" to smooth flow, and removed the internal flapper valve in muffler), nonetheless stock catback is still employed- just rigged.
After I overhauled the catback I just kept it that way - sounds buitiful. Now I'm running W/M at 25psi with no pinging using same gutted exhaust duct.
