stock evo9 run
Old Mar 23, 2007 | 06:07 AM
3000ways's Avatar
You said you ran a few times? What were some of the other times?
Old Mar 23, 2007 | 08:00 AM
NIevo's Avatar
What do you mean the boost up from 18-20? Are you saying he has a boost controller? Also are you talking peak boost or at redline cause the IX's already run 20psi stock.
Old Mar 23, 2007 | 12:51 PM
LILKEEZY2003's Avatar
Thanx guys i ran 13.0@104 before he dropped the exhaust he ran a 12.9@107 then i ran a 12.4@107 when i drove the car after the dropped exhaust...and i dont know he told me it was on about 20 psi...i thought that was stock myself so...but i dont know....i know the car is just stock ...
Old Mar 23, 2007 | 01:48 PM
homiusang's Avatar
I believe the time, but you just can say it's stock since you run an open exhaust after the downpipe. It's not stock anymore. Weight reduction, on the other hand, is more acceptable by the general public.
Old Mar 23, 2007 | 02:06 PM
JMPZ's Avatar
wouldnt say stock but all in all a sick run
Old Mar 23, 2007 | 02:57 PM
mdog's Avatar
Great runs regardless. I thin it's pretty common sense that when you drop the exhaust from the dowpipe back or test pipe back that your car is no longer stock. All those bent metal thingies came on the car, and now they or no longer there, I think that's pretty direct.
Old Mar 23, 2007 | 10:06 PM
well he upped the boost from 20-23 and i ran...a 12.2@110 so the car is getting their....
Old Mar 23, 2007 | 10:41 PM
mdog's Avatar
Keep plugging away at it. Same setup with the dropped exhaust but upping the boost to 23psi? Good runs and before long you'll probably see that 11sec. slip if you keep it up. And the 23 is the spike correct, or the taper?
Old Mar 23, 2007 | 10:45 PM
thats the spike....yea we are hoping i can get the car into the 11's...i only got 2 runs tonight since the track was so packed so ...the 1st run was 12.4@109 then the last run was the 12.2@110 so its getting their...
Old Mar 24, 2007 | 08:16 AM
NIevo's Avatar
So he does have a boost controller? Even if set for stock boost it would have helped reduce taper. Impressive runs but far from stock.
Old Mar 24, 2007 | 08:20 AM
SilverNine's Avatar
nice times for an untuned car...
Old Mar 24, 2007 | 08:28 AM
scott yo's Avatar
Thats pretty sick!
Old Mar 24, 2007 | 12:12 PM
fastrob691's Avatar
if he doesn't have a flash or something I would be surprised, but either way 12.2 with mbc and dropped exhaust is something. I have run into many people claiming their cars are stock when in fact stg 2, they claim since no aftermarket turbo or cams all stock.
Old Mar 24, 2007 | 07:36 PM
the car has a forge mbc and the dropped exhaust...other from that the car is stock....
Old Mar 27, 2007 | 08:51 PM
edweazy2003's Avatar
Car is running really strong for those mods it has.
Turbojunkie
Northwest Region
16
Mar 11, 2008 09:10 AM
Light
May 4, 2006 09:06 PM
4WS Tuning
Jan 21, 2006 11:07 AM
Warrtalon
Jun 22, 2005 06:41 AM
Warrtalon
May 16, 2005 07:26 PM
