Can it be done?!?!?
Old Aug 21, 2007 | 08:42 AM
TTP Engineering's Avatar
Originally Posted by Ang Wen Yan
Add a 4.11 final drive should solve your problem.
Huh?
The 4.11 should not be used by anyone, other than for a land speed record.
I have seen what this final drive does to launches. It makes them impossible.
Old Aug 21, 2007 | 11:59 AM
BURNALL_4's Avatar
the 60' is a 1.74....im still learning in that aspect, im talking the shifting.....is where I make most of my time. i know with a clutch i should pull a low low 1.6 maybe a 1.5.
Old Aug 21, 2007 | 12:09 PM
ecms's Avatar
i went a 10.9 with 513whp with a 1.6 60'
Old Aug 21, 2007 | 02:15 PM
Ang Wen Yan's Avatar
Originally Posted by TTP Engineering
Huh?
But he have nitrous of which is going to help.
Old Aug 21, 2007 | 02:28 PM
No it won't. The Evo in Puerto Rico I witnessed had 850whp and 150shot off the line.
It could not do anything a stock Evo couldn't off the line, even with slicks.
Way too friggin long of a final drive.
Old Aug 21, 2007 | 02:41 PM
Kevindanger's Avatar
Is that true for the 6 speed too? If they ever made one
Old Aug 21, 2007 | 02:55 PM
93GSR1's Avatar
Originally Posted by 05 EVO RS
Can a 450whp evo that weights 3200 with the driver go 10.99?
Yes It is possible, but not easy.
Less weight would make it alot more possible, but I'm thinking stripped race car style.
With 450whp lt will mostly depend on your launch and 60ft times.
You'll also need a 6-8point roll bar to run anything faster than a 11.50
3200lbs race weight is pretty light for a EVO. Especially a 10sec street EVO.
A Curb weight around 3250 + 120_RollBar + 180_Driver = 3550lbs raceweight. Pulling 350lbs out of you car wont be easy unless you are building a race car.
10.9 with 500whp would be more like it
I'd love to know how much some of these 9second EVO's weigh. I wish more people would weigh there cars ...I just go to truck stops on the sides of highways and pull up on the scales
Old Aug 21, 2007 | 04:29 PM
AZ EVO IX MR's Avatar
do you have or know of any videos or links about this?? Launching with the final drive. 4.11 or 3.73
Old Aug 23, 2007 | 03:02 PM
+1111.And it is not an easy task to hit 10's on stock turbo without very light car.And the 5th shift will hurt a lot.
154
Aug 16, 2015 12:57 AM
FullBlown
27
Jan 18, 2007 06:03 PM
Elvis
Oct 25, 2006 07:39 PM
Markourn
70
Oct 5, 2006 01:48 PM
J8dailo
Jan 27, 2005 10:20 AM
