Looking for some input on what it takes to hit 160mph plus in the 1/4mile
Old Aug 21, 2007 | 01:51 PM
  #31
AZ EVO IX MR's Avatar
Paul, you should try the hks kansai intake manifold, i bet you would get more power.
Other than that go 2.4 with a final drive lol
Old Aug 21, 2007 | 06:17 PM
  #32
AWD Motorsports's Avatar
Originally Posted by e.shelman
What details would you like to hear? He plans on attending Maxton. This was done on gas with no juice. Mike says the car has alot more in it. The 215.9 run was on a bogged launch.
well ill be at maxton next month i hope he comes.. i saw his car on a vette site that was discussing the event.. im just amazed at the speed for a car that has horrible aeros.. in the mile, aeros are everything not just hp..
Old Aug 22, 2007 | 09:48 AM
  #33
R/TErnie's Avatar
Switch to a full coilover setup and corner balance the car.
Run less than 14psi in your slicks! I think Eric@shep mentioned this.
Work on getting air to flow OVER the car and NOT under it. A belly pan for the front and the rear of the car would work great.
Maybe a 'moly cage instead of a DOM Mild steel cage.
some1 mentioned before...lexan windows. (tons of weight to be saved there)
Your driveshaft? Are you running a lightweight shaft?
Lug nuts... see if you can get lighter lug nuts rather than steel ones. make sure you studs are only as long as they need to be.
Lighter rotors. Maybe switch to a wave rotor like the bikes use with an aluminum hat. Your brake pad material can be made to have less bite during acceleration.
switch to an aluminum exhaust instead of a FULL 3.5" Stainless steel unit.
a little math for you on weight of piping...
Comparison between 4" SS, 3" SS, and 4" AL tubing.
Weight
Stainless Steel 4" tubing is .086" thick (14awg)
Stainless Steel 3" tubing is .065" thick (16awg)
6061 Aluminum 4" tubing is .065" thick (16awg)
Circumference of a 4" pipe 12.57"
Circumference of a 3" pipe 9.43"
Density of 304 Stainless Steel (lb / cu. in.) 0.285
Density of 6061 Aluminum (lb / cu. in.) 0.098
for a 4 foot section of downpipe (assuming its straight)
4" ss.... 12.57*48*.086= 51.89 cu. in.
3" ss.... 9.43*48*.065= 29.42 cu. in.
4" Al.... 12.57*48*.065= 39.22
(4" SS) .285*51.89= 14.79 lbs.
(3" SS) .285*29.42= 8.38 lbs.
(4" Al) .098*39.22= 3.84 lbs.
Melting Points
304 Stainless Steel (Deg F) 2650
6061 Aluminum (Deg F) 1090
Aluminum Oxide (Deg F) 2054
Highest EGT (Deg F) 1700
Also...if you would've used teh TiAL housing on your 42R...bunch of weight savings. Also if you do your manifold in 16 gauge inco or 316ss...bunch of weight to be had there as well.
Liquid to AIR IC.... you have a race car right? why not use it?
Nitrous? I know you have nitrous paul. Nitrous ALWAYS picks up MPH
Old Aug 22, 2007 | 03:53 PM
  #34
DSMu4ia's Avatar
Lose the mirrors.
Alignment, alignment, alignment.
Weight, while important, isn't everything.
Tape or block every orifice/opening/hole in the front of the car.
Old Aug 23, 2007 | 06:46 PM
  #35
Paul Nelson's Avatar
Weight
Melting Points
Working on allot of this just takes so much time Thankyou for the input
Old Aug 23, 2007 | 06:48 PM
  #36
Originally Posted by DSMu4ia
Lose the mirrors.
Ive been using the white ducktape to close up the front end. Im going to put some lexon on the holes on the bumper looks much better
EvoDan2004
1959
Jun 4, 2025 12:32 PM
Joshs EVO
60
Oct 22, 2011 09:51 PM
evillancer06
Dec 21, 2009 07:14 AM
BLKCarbonEVO
Oct 26, 2009 11:18 AM
TrinaBabe
88
Oct 31, 2007 03:04 PM
