First time to the track, I did allright.
Old Jan 5, 2008 | 10:37 PM
  #31
Shaun@AWDMotorsports's Avatar
Originally Posted by bbyct9agsr
Well I ran my car for the first time tonight, I ended up running a 13.54 at 101 mph I had a 1.5 for a reaction time and a 2.3 60foot. Ive never launched an awd car or been to the track before so I think I did allright.Hopefully I do beter next weekend when I go back.
did you start off in 3rd?
I ran 12.4 @ 111
Old Jan 5, 2008 | 10:51 PM
  #32
bbyct9agsr's Avatar
I have an 8 you have a 9.also I know a guy that has a 9 rs with an hks hardpipe, tbe and a tune running 12.2's consistently. you only ran a 12.4 with more mods? how are you gonna call me slow?
Old Jan 5, 2008 | 11:04 PM
  #33
bbyct9agsr's Avatar
not to mention, that all of you who are talking down on me have an evo 9.....MIVEC means more power. I have an 8 and damn proud of it.
Old Jan 5, 2008 | 11:13 PM
  #34
BURNALL_4's Avatar
Originally Posted by TouringBubble
A few tips ...
1) Don't baby the clutch on the launch. When the slack is gone from the drivetrain, get off the clutch quickly!
2) Leave on the 3rd yellow, not on the green. This will lower your R/T. You have ~7" of rolling room before you trip the lights if you stage correctly.
3) Stage "shallow" (where the second set of staging lights are just coming on) for the best trap speed and ET. This basically gives you a running start.
4) Shift above 6800 or so. I've gotten the best results in my MR shifting at ~7200, but it will be different in your 5 speed. Try different shift points and watch your trap speed to figure out the best shift point.
Good luck on future trips!
Great ****!!!...I meen tips!
Old Jan 5, 2008 | 11:14 PM
  #35
wangamachang's Avatar
do evo 8's have two steps? if so, just rev it up to 5k, and let mitsubishi do the rest...except drop the clutch of course
Old Jan 5, 2008 | 11:19 PM
  #36
bbyct9agsr's Avatar
you have to flash the 2 step down because it comes stock in 03 set at 7600
Old Jan 5, 2008 | 11:21 PM
  #37
bbyct9agsr's Avatar
granted the launch would be spectacular but the broken t-case would be expensive
Old Jan 5, 2008 | 11:22 PM
  #38
mattevo9's Avatar
i ran a 13.0 @107 with a 1.9 60ft r/t of .595
mods are 3'' tbe w/ tp,intake,hallman boost controller,act hd street clutch w/ prostreet flywheel, untuned with 93 octane
Old Jan 5, 2008 | 11:39 PM
  #39
SixOneNine's Avatar
Remember that the fastest and most powerful Evo's out there are 8's
Old Jan 6, 2008 | 12:06 AM
  #40
SOEuro's Avatar
Don't plan to replace your clutch based on the results of bad drivers ... I've got about 30 drag launches on my stock clutch and it still holds fine. I'm putting down around 350 whp as well.
either you dont have as much power as you say,or your not launching right
the stock clutch cant handle a good launch with that much power,BTW,i cut consistant 1.7/1.6s with it.....to the OP,it takes some time so keep praticing and read up on launching
Old Jan 6, 2008 | 12:11 AM
  #41
aznRice's Avatar
Because they have been worked on since it first came out?
Old Jan 6, 2008 | 12:33 AM
  #42
Warrtalon's Avatar
Huh? Launching hard doesn't break your t-case. Dumping the clutch at 7k kills your t-case (and doesn't give you a good launch).
The launch sucked, the time is weak, the mph is weak, and you posted in the wrong forum. So what? Go back and do it again - you'll get better. Never go if you only get one run and never go if you're not going to launch. It's absolutely worthless if you don't launch hard enough to get 1.7 60's.
Old Jan 6, 2008 | 05:07 AM
  #43
SixOneNine's Avatar
And how long has the 9 been out now? If that were the case, the 1st generation of Evo's should be dominating the tracks. You do know there were Evo's before the 8 right?
gIGoN
Jan 3, 2017 01:43 PM
lousEVOxmr
May 8, 2009 02:51 AM
Onkar02
Lancer Troubleshooting
Mar 24, 2008 10:02 AM
blaze_125
15
Mar 12, 2006 04:10 PM
freakoz
Aug 3, 2004 12:05 PM
