How harmful is it to no lift shift?
Old Jan 6, 2008 | 09:24 PM
shunderwunder's Avatar
I have an 06 EVO IX SE & will be taking it to the strip when they open back up & was wondering how hard it is on the drivetrain to no lift shift the car. When I go to the track I should have a TBE, Injen intake & IC pipes, Boost controler, & Dyno tune, but will most likely be on the stock clutch. Im not so much woried about the clutch since I know it's going to need to be replace fairly soon anyway. I was wondering if no lift shifting is overly harsh on the rest of the driveline. Is it any worse than launching the car from the 2 step (not dumping the clutch)?
Old Jan 6, 2008 | 09:38 PM
version 2 beta's Avatar
it depends if you have a dog box transmission...
You're not going to last long no lift shifting on a stocker trans.
Ask any of the major drag racers on here... Devo, ETS, AMS, Bushy, etc., etc., etc..
laakness's Avatar
You should run a NLTS ecu patch from tephra so the RPM's will drop a bit. Hopefully you don't miss a gear with your foot stuffed in the gas pedal
Old Jan 6, 2008 | 10:00 PM
The tranny (5 speed), TC, & diffs are stock. Is this patch something I can have done when it is dyno tuned or is that something I have to get elsewhere? Sounds like this may not be a good idea for the car.
Old Jan 6, 2008 | 10:07 PM
SlowSportSedan's Avatar
if you shift fast it can hurt more than help.... that just keeps you from bouncing the limiter... but will also add a little lag if you dont suck at shifting
Old Jan 6, 2008 | 10:19 PM
I tested it today & shifted from 3rd to 4th at 7000 RPM & did not hit the rev limiter. If I do miss a shift will it hurt something or just bounce off the rev limiter? If I do it right will I be asking for trouble?
Old Jan 6, 2008 | 11:38 PM
EricJ@AMS's Avatar
I wouldnt expect the syncros to last too long with alot of no-lifting. Other than that, it really doesn't hurt much else, especially with a stock clutch.
Old Jan 6, 2008 | 11:44 PM
xspsi4's Avatar
Well my fully built TRE trans broke after 2 months of constant nl shifts with an un sprung act 6 puck. I ended up shearing my 3rd gear syncro to pieces, 25.00 fix but It took me 1 whole day to do the labor. On the other hand it sure felt good and I would have it no other way. why shift like an old woman?
Old Jan 7, 2008 | 06:35 AM
laakness's Avatar
True, once you get it dialed in at the right rpm drop it's pretty slick as long as you stay consistant with shifting
Old Jan 7, 2008 | 07:28 AM
EVIL_EVO_VIII's Avatar
I have 24k miles on my Evo IX and done tons of nlts passes. Now im getting locked out on 4th gear pass 7k rpms, its not grinding but just locking me out. Possibly clutch going?
Old Jan 17, 2008 | 03:23 PM
recompile's Avatar
Definitely clutch.
JDavenport
33
Aug 22, 2016 04:44 PM
kimsan808
Pacific Northwest
Jun 16, 2012 01:55 PM
billsIXmr
May 25, 2010 12:10 AM
KY
14
Sep 16, 2007 05:44 PM
Aby@MIL.SPEC
Jul 22, 2007 04:49 PM
