First runs of the season
Old Apr 26, 2008 | 04:35 PM
evogottago's Avatar
Here are my times
60ft -1.7701 -1.7349 -1.8241
330ft -5.2523 -5.2710 -5.2839
1/8 ET -8.1123 -8.1380 -8.1150
1/8 MPH -85.85 -86.06 -86.87
1/4 ET -12.6873 -12.6670 -12.6210
1/4 MPH -105.34 -108.41 -108.90
Mods-
Buschur TBE w/ cat
Buschur Intake
Lower ICP
Cosworth Cams
Walbro Pump
Buschur MBC
Ported Ex Mani
Ported Int Mani
Ported T. Body
S.S. O2 Housing
Buschur Reflash
Torque- 310 @ 3300rpm Horsepower- 340 @ 6700rpm (Buschur's Mustang Dyno)
This is my first time EVER at a track let alone launching the car for real. The track is by far the worst track in ohio (la rue). I think that is some of the reason my times were so crappy although I'm not making excuses. I was looking for 115+ traps and low 12's. What is the biggest reason for my high times?? Crap track?,Bad driving?, Something wrong with the car?? I would try to figure it out myself but idk how to read a timeslip as far as what needs to be improved.
Driving style- Launch at 6000 (bogged a little) shift at 7k every shift, and ride out 4th til the end of the strip
Old Apr 26, 2008 | 04:39 PM
YzBrad99's Avatar
Bad track probably. the driving can always improve. Keep it at 7k shifts as there is no need to rev higher on a stock turbo. Youll be suprised at what practice can do. I have the same car and couldnt feel more sorry for your stock clutch as mine is almost toast.
Old Apr 26, 2008 | 04:59 PM
evogottago's Avatar
Nah.. I launched it every time (only once all out at 6000) and it didn't slip or burn at all .. very clean launches (which surprises me) Not sure how many times i can launch it w/o needing a new one.. guessing a while as long as i dont roast it
Old Apr 26, 2008 | 06:10 PM
mcwop23's Avatar
you're probably pulling timing up top pretty badly, your 1/8th MPH is a little low but you should gain 24-27MPH in the last 1/8th. I would do some logs and see if you're knocking in 4th.
Old Apr 26, 2008 | 06:12 PM
j14mp's Avatar
yea ur traps should be WAYYYY higher then that... with my mods i was trapping 113 easy on a full tank of pump rolling off the line.
Old Apr 26, 2008 | 09:19 PM
evogottago's Avatar
I KNOW!!! lol.. not yelling.. just saying.. That's why after my first run i was like..wtf. But that's why i was wondering if it was the track that was slowing me down..
Old Apr 26, 2008 | 09:30 PM
max2evoix's Avatar
Originally Posted by evogottago
Here are my times
Mods-
Buschur TBE w/ cat
Buschur Intake
Lower ICP
Cosworth Cams
Walbro Pump
Buschur MBC
Ported Ex Mani
Ported Int Mani
Ported T. Body
S.S. O2 Housing
Buschur Reflash
driving skills need to be improved especially with all those mods..
Old Apr 26, 2008 | 10:53 PM
mcwop23's Avatar
it's not a driving issue, the launches look good.
Old Apr 27, 2008 | 02:17 PM
evogottago's Avatar
That's what i was thinking .. I read on here that 1.7's are pretty good 60ft's. So what do you think would fix the problem?? Try a diff track and see what happens.. new tune?? What?!
Old Apr 27, 2008 | 02:24 PM
mcwop23's Avatar
re-tune if you are knocking
also do a boost leak test
Old Apr 27, 2008 | 02:53 PM
evogottago's Avatar
I'm sorry, this is going to sound completely ignorant.. but what exactly should i do to figure out if im knocking or not.. should i drop it off at buschur and see what they have to say, and just have em do a boost leak test while they're at it or what??
Old Apr 27, 2008 | 03:46 PM
FathouseFab's Avatar
To see if its knocking, download mitsulogger or evoscan and do a few pulls. Do you have a wideband in the car?
Your 60's are good but you could use some practice on your shifting. The 1-2 shift is killer important. Gotta get that 330 down.
Fathouse
Old Apr 27, 2008 | 04:23 PM
evogottago's Avatar
I would, but sadly I don't have a laptop to use mitsulogger or evoscan
03BBY1088
Mar 29, 2015 06:43 AM
MillDogg13
Apr 9, 2009 01:38 PM
evogottago
May 23, 2008 09:41 PM
Str8Nasty
Sep 30, 2007 06:22 PM
03redtype-s
Nov 20, 2006 01:08 PM
