Should I be in 11's??
Old May 20, 2008 | 06:32 AM
evogottago's Avatar
Here are my times
60ft -1.7701 -1.7349 -1.8241
330ft -5.2523 -5.2710 -5.2839
1/8 ET -8.1123 -8.1380 -8.1150
1/8 MPH -85.85 -86.06 -86.87
1/4 ET -12.6873 -12.6670 -12.6210
1/4 MPH -105.34 -108.41 -108.90
Mods-
Buschur TBE w/ cat
Buschur Intake
Lower ICP
Cosworth Cams
Walbro Pump
Buschur MBC
Ported Ex Mani
Ported Int Mani
Ported T. Body
S.S. O2 Housing
Buschur Reflash
Torque- 310 @ 3300rpm Horsepower- 340 @ 6700rpm (Buschur's Mustang Dyno)
This is my first time EVER at a track let alone launching the car for real. The track is by far the worst track in ohio (la rue). I think that is some of the reason my times were so crappy although I'm not making excuses. I was looking for 115+ traps and low 12's. What is the biggest reason for my high times?? Crap track?,Bad driving?, Something wrong with the car?? I would try to figure it out myself but idk how to read a timeslip as far as what needs to be improved.
Driving style- Launch at 6000 (bogged a little) shift at 7k every shift, and ride out 4th til the end of the strip
Old May 20, 2008 | 06:36 AM
TeStUdO's Avatar
Your 60' isn't that great, but with those traps, you aren't close to 11's. With the power you made on the BR dyno, I would expect your traps to be higher.
Try a compression and boost leak test.
Old May 20, 2008 | 10:46 AM
vaflyboi757's Avatar
with those modz, you should be trappin between 115-119. check ur car
Old May 20, 2008 | 11:03 AM
gamebred26's Avatar
what clutch do you have?
Old May 20, 2008 | 11:16 AM
EatSleepBoost's Avatar
same^. since u have full exhaust, cams, n boost controler ur top speed should be higher. how much boost are you running? if u want to be in the 11's u need to trap about 10mph faster
Old May 20, 2008 | 11:18 AM
bbyevo8u's Avatar
what oct are you tuned for 91?
Old May 20, 2008 | 01:08 PM
fugiwara's Avatar
take out the cat you'll have better chance
Old May 20, 2008 | 01:16 PM
wevo1985's Avatar
your trap speeds are real low. make sure your not getting any knock and pulling time. that was happening to me when my car was alittle lean.
Old May 20, 2008 | 01:23 PM
2 Deep Motoring's Avatar
your trap speed is real low for the mods you have... i have all the basic bolts on's minus intercooler and i ran a 12.1@110
Old May 20, 2008 | 01:30 PM
SOEuro's Avatar
you HP should get u 11s
Old May 20, 2008 | 02:16 PM
Ph3n1x's Avatar
Mods /= 11's
Mods and Driver = 11s
Looks like your losing is by the 1/8th and to the 1/4 based on your Trap. Datalog the car.
Old May 23, 2008 | 08:21 PM
eponti's Avatar
For the mods you should be trapping a lot higher than 108.Something is not right.
Old May 23, 2008 | 08:25 PM
evo@24psi's Avatar
Looks like you were consistant so i dont know if it was your driving? You could consistantly suck at driving but ill give you the benfit and say something is up with the car. Good luck man!
Old May 23, 2008 | 09:41 PM
SpooksEvo's Avatar
dude pretty good for first time at the track. Consistent times. They are right though you should be trapping higher and are capable to run 11's with more practice.
evo81234
Evo X Dyno Results
Jun 4, 2014 04:17 PM
Joe's Evo X
Jul 10, 2009 04:22 PM
BigAeVo
Jun 18, 2006 02:16 PM
PeteyTurbo
May 8, 2005 11:43 AM
