launching with "slicks"
Old Nov 1, 2003 | 11:51 PM
nocar's Avatar
does anybody here run there evo with some kind of drag / slick tires such as the DOT approved Nittos or bf goodrich drag tires
i would imagine it being a good idea to pick up an aftermarket cutch since there would be alot of clutch slip due to the increased grip, or would that put a larger amount of stress on the tranny if you werent feathering the clutch as much since you could let it out faster..
Old Nov 3, 2003 | 12:47 AM
95snoozer's Avatar
I would definitely not do that on your stock clutch
Old Nov 3, 2003 | 12:49 AM
95snoozer's Avatar
but why use slicks? are your rear wheels spinning? the fronts?
I would just try some autocross tires. slicks are gonna make you bog like a ************ if you are not really privy on launching.
Old Nov 3, 2003 | 04:10 AM
TypeIII's Avatar
Unless you're putting down an insane amount of power, drag slick is really not necessary for an AWD car like the EVO8. Lowering your tire pressure slightly should really fix the problem for you, and that is, if you are putting down some serious power.
Old Nov 3, 2003 | 04:50 AM
Evo11V's Avatar
Veteran: Army
You dont need slicks, slicks are for your mustangs. There should be no tire spinning you have AWD and if you launch right there will be no tire spinning even at say 6K launch. AL has a 11s 1/4 and he uses stock tires... They are the best!
Old Nov 4, 2003 | 06:44 AM
MrBonus's Avatar
Umm... Other than outright disconnecting the driveshaft to the rear, how would you expect to heat a sticky tire up?
Old Nov 4, 2003 | 04:21 PM
Kris in the STi's Avatar
youre gonna need a lot or power to need mroe then the stock a046's.....
however....with a 2.5 and bridgestone re070 225/45....you can pull 1.674 660ft's...with only a downpipe......i know from experience
Old Nov 5, 2003 | 03:41 PM
95snoozer's Avatar
you have higher gearing
Old Nov 15, 2003 | 01:41 AM
Buckkaaaa!!'s Avatar
AWD = no slicks needed for under 600 whp
Old Nov 22, 2003 | 09:43 AM
HIGH REV's Avatar
I remember seeing a red WRX in a magazine that uses BFG drag radials and it runs 10s or 9s. I think you can run drag radials, but remember to upgrade everything involved in putting the power down sufficiently because you're bound to break something if you don't modify intelligently.
4g63sidewinder
For Sale - Wheels / Tires
Jun 2, 2017 05:10 PM
cvnick
May 20, 2016 06:45 AM
rodent
May 19, 2016 07:51 AM
TwinTurboM3
Apr 16, 2016 01:57 PM
PATRICK B.
Sep 5, 2008 09:54 AM
