Evodan new personal best 10.37 @ 137 MPH
Old Sep 1, 2010 | 08:20 AM
  #151
Mellon Racing's Avatar
Originally Posted by Sean@Iveytune
What brand tire? WHat size?
Sean
M&H I don't recall the exact size
Old Sep 1, 2010 | 09:50 AM
  #152
Sean@Iveytune's Avatar
So this was like a DOT cheater slick type of tire?
Sean
Old Sep 1, 2010 | 11:06 AM
  #153
dsmfan95's Avatar
Originally Posted by Mellon Tuning
it was a 15" dot radial, I think it's just over 26" IIRC
The video of that run states you were on BFG's which would make more since. 9000rpms on a 26" tire would put you in the upper 140mph range with an Evo8 4th gear.
Old Sep 1, 2010 | 11:27 AM
  #154
oh I must have made a mistake. Originally I had BFG DR's on stock 17" rims, but later changed to the 15" M&H DOT DR, they re considerably softer and a little taller. I'm pretty sure I was using them when I did the e85 run 10.44 @ 139.8 (spinning and bouncing)
Old Sep 3, 2010 | 02:01 PM
  #155
EvoDan2004's Avatar
here is the start of my boost spoolup testing. https://www.evolutionm.net/forums/ev...es-tested.html next will be on the actual street and then EBC VS MBC and what spools up faster in the lower gears and when you shift. the tests will probably be around 34/35 psi
Old Sep 3, 2010 | 05:43 PM
  #156
FathouseFab's Avatar
The manual will win, what manual are you testing?
I run alot of WG spring pressure, and a needle valve from a local hydro shop setup to regualte boost to the top of the gate. Works good.
Fathouse
Old Sep 3, 2010 | 06:58 PM
  #157
EvoDan2004's Avatar
Fathouse
I will be using a hallman mbc vs apexi Avcr. I run 22 PSI springs in each waste gate.
Can you explain this quicker spool with using the top port on the waste gate? Thanks.
Old Sep 14, 2010 | 02:12 PM
  #158
YANG TURBO's Avatar
nice number dude
Old Sep 14, 2010 | 03:18 PM
  #159
ravnos04's Avatar
freaking 8-10 sec bikes and they can run no prob....but a 10s car WATCH OUT! good run dan
Old Sep 26, 2010 | 01:55 PM
  #160
EvoDan2004's Avatar
went to the track today. not a good day. sat in line for nearly 3 hours. i only got 1 pass in. and of course i messed it up. but i can tell the car is gonna crank when i get it right. boost is holding and hitting so much harder/cleaner. this was 35/6 psi
1.78 60
car was braking up some too. ''i think it needs new plugs''
missed 3rd gear
11.0
136
not happy with this at all. but you cant run perfect every time. the car is going to Ivey tune for a finished 100oct tune and 38/9psi. so we can stop dillying around. maybe this week.
Old Sep 26, 2010 | 02:11 PM
  #161
06MREvo's Avatar
1.78 60
missed 3rd gear
11.0
136
Quit dillying around and tune this beotch on e85 and run 9s!...I finally got my car running again and its getting tuned oct. 4th and plan on going to Island that friday...ill let u know sir...
Old Sep 26, 2010 | 02:14 PM
  #162
EvoDan2004's Avatar
i want 9.99 on street tires and 100oct. ''street car'' then i add slicks and E85. ''race car'' these are my goals. im close. i just need to get it right.
Old Sep 26, 2010 | 02:26 PM
  #163
apagan01's Avatar
goood job Dan alll all you have done , i like how you keep it humble and small, but still getting er-done
Old Sep 26, 2010 | 02:27 PM
  #164
compscibOi's Avatar
Haha nice! Good "work"
Old Sep 26, 2010 | 03:14 PM
  #165
4g94's Avatar
great numbers!!
