What's holding me back?
Old Mar 12, 2011 | 02:51 PM
B Fletch LV's Avatar
Last December I took my 03 out with nothing but a 3" catless exhaust. I ran 13.8 at 97mph. I recently put on everything listed in my sig, plus an o2 housing, and got a street tune. The tuner put on no lift to shift, and set the rpm drop as 1500. I couldn't break into the 13s last night. No matter what I did. My best guess is the no lift is the culprit. What do you guys think? Any input appreciated
Edit: same clutch/flywheel and tires as last time too
Old Mar 12, 2011 | 03:01 PM
06MREvo's Avatar
Post a breakdown of the slip...
Old Mar 12, 2011 | 03:10 PM
BoostWhore's Avatar
Lots of things to rule out... could be something mechanical even.
Check your car for boost leaks via using a pressure tester
You should be able to run more boost than 22psi depending on your tune
Driving technique could be a huge portion of it. post some 60ft times. The mph seems kinda low to me.
Old Mar 12, 2011 | 05:10 PM
BEEVO67's Avatar
Spark plugs? Most common mistake for all turbo cars!
Old Mar 12, 2011 | 09:29 PM
wizzo 8's Avatar
Tire psi, weight, outside temp all the same?
Old Mar 13, 2011 | 01:44 PM
All the same, spark plugs were not changed that long ago. I can't post pics of the slips (no way to upload) but the 60' times were close, then it just got slower and slower as i went further down the track. If my 60' was identical the 1/8th was .2 slower, 1000' .3 slower, eventually ending in .4 slower. I found last night my TV shaft seals are leaking. Gonna take off no lift and try and get those in by next Friday (track day)
Old Mar 13, 2011 | 06:08 PM
tlcoll1's Avatar
Just post the numbers from the timeslips. You should be at in the 105-109 MH in the 1/4 and 80-85 MPH in the 1/8th. If your TB seals are leaking, that could explain it.
Old Mar 13, 2011 | 06:21 PM
GEJEN's Avatar
make a list of the things that you think could be slowing you down and then start by eliminating with the easiest options on that list i.e. NLTS, spark plugs or a boost leak test.
Old Mar 31, 2011 | 09:07 PM
Nismo2evoawd's Avatar
Whats your 60 foot times?
Old Mar 31, 2011 | 09:33 PM
project_skyline's Avatar
1500 rpms for NLS is too much. I have mine set to like 600, I'd say 1k is the max.
But thats probably not your problem.
Post the numbers from the slips from your last time out and the most recent.
Include track, date, and conditions.
Blueboxer7
Nov 19, 2014 10:53 AM
WAM
Feb 5, 2009 06:57 PM
KevinD
Apr 18, 2008 12:48 PM
DublXL
31
Feb 7, 2006 07:55 AM
